does anyone do them built onto a standard mountain bike wheel? Looking as an idea for a potential new build project but cant seem to find them anywhere, could be googling/searching for completely the wrong thing, and if they don't, why don't they?
cheers all
goldtec?
when you say standard, you mean 26"?
you obviously won't be able to use discs either. i've a surly hub and built it into a rim myself. relatively easy to do as there is no dish on the wheel.
I've got a Mich screw on frewheel hub built onto a 26" Velocity aeroheat rim of some sort and spaced to use as a fixed i'd be willing to sell if you're interested?
third edit to try and get the pic up here:
fourth go...
[img]
[/img]
and if that doesn't work the pic is here http://www.flickr.com/photos/39048531@N00/3463961436/
woop woop! 😀
Just use a disc brake hub and bolt a sprocket onto the disc side - problem here is you have to use rim brakes and if you do flip/flop your brakes and wheel dish have to be set up perfectamundo.
Works for me... although quite why you would want to do such a stupid thing I cannot reason 😆
135 or 120mm?
There's a huge choice for 120mm, but if you want a MTB wheel then your choices are limited. The On-one double-fixed hub is a bargain. But if you want to run a disc brake and a fixed cog then the only option I can think of is the Surly (which is what I've got but I can't recommend it due to short bearing life).
Have a gander round this site
[url= http://www.63xc.com/howto/howto.htm ]www.63xc.com[/url]
Might help you out?
are the on one hubs, flip flop or just as the name might suggest, fixed both sides?
Flip-flop just means double-sided. Double fixed is the most versatile. The thread's the same for a fixed sprocket and freewheel, but you also get the option of using a lockring. My On-One has lasted really well. Goldtec are good and can do a 135 spacing.
why not ask your lbs to build one for you ? Any shop that offers wheelbuilding should be able to sort it out for you
also any of the cup and cone hubs should be ok to re-space with a larger axle for 135mm spacing if thats a problem as well
Thanks all, looks like the On One is the best option for me, now just need to find a decent/cheap V brake rim and pass onto a mate for building duties, pics will follow when built
Oh they to coloured Mary Bars!!!
Brill for SS when riding to trails on road at speed and no spinning out and then swapping wheel over for mtb ratio.
Just bring some gloves that don't stain with the muck you get on your hands.
