five Ten shoe cover...
[Closed] five Ten shoe covers - home adapted - anyone else?
6 Users
[url= https://c1.staticflickr.com/6/5801/30938482632_0bcce1fd6b_k.jp g" target="_blank">https://c1.staticflickr.com/6/5801/30938482632_0bcce1fd6b_k.jp g"/> [/img][/url][url= https://flic.kr/p/P8VP1m ]IMG_1428[/url] by [url= https://www.flickr.com/photos/35221565@N04/ ]olney_684[/url], on Flickr
Tested these puppies out last night for the first time. Seemed to work ok. The Tenn shoe covers seemed good for the job as they are cheap and have a double toe kind of thing that you can cut to make more space and are still well stiched. Tired of destroying expensive five tens in the wet. I stitched/pegged back some of the material to open up the hole and try to keep out fo the way of pins.
In my research I saw a post from a year or so ago of someone doing a similar thing, anyone else done this?
Posted : 18/11/2016 10:09 am
That looks terrible to me, I'd have as much pedal on the overshoe as I would on the sole of the shoe itself. Would imagine the overshoe would just be torn to pieces in no time (assuming it has some grip)
Posted : 18/11/2016 10:17 am
Agreed, the neoprene is smack in the way of the pedals gripping the grippy soles?!
Posted : 18/11/2016 11:16 am
My mate just gaffer tapes carrier bags round his feet.
I just put merino socks in Dexshell or Sealskinz socks, accept that my Teva Links will get wet and that after a while some water will sneak in the top of the socks, but if I get wet at least I stay warm.
I've got two pairs of Links too (just, they are old and battered) so whilst one pair is drying I can ride in the other.
Posted : 18/11/2016 11:26 am
Used some Planet-X neoprene overshoes on my flat shoes. Found they were a bit tight but managed to squeeze them on. I run a size 11 shoe, what size shoes and overshoes are you using here dogmatix?
The Planet-X one's lasted about a year of commuting and winter riding. The main thing that killed them wasn't the pins on the pedals but the hike-a-biking and any walking that happened.
Posted : 18/11/2016 11:35 am
Not sure if its the angle of the image but the right area is exposed for me. The centre neoprene is in the arch of my foot. I had no issues at all. Grip was just the same. I'll see after a few more rides. very easy to pin back a bit further If I need to. They did come out bone dry.
Posted : 18/11/2016 11:39 am
Guess it depends on how you ride flat pedals. I personally switch between ball and arch and anywhere in between depending on the terrain and what I'm doing. Sometimes I even use my shin.
I think that set up would tear up too quickly for me but it's interesting - wonder if there's a way to expose the sole but keep a seal around the edge - probably not without it slipping all the time.
Posted : 18/11/2016 11:48 am
Paul@RTW - Member
Yup, spend most of my time somewhere in between ball and arch. Eg:
but with none of the style/skill/speed
Posted : 18/11/2016 11:56 am
Just edit out that final line qualifier, I just figured that was a picture of you until I read that bit.
<whispers> No one will ever know </whispers>
Posted : 18/11/2016 12:11 pm
agree does depend how you place your foot. I tend to have my toes just over the front. But as I say I might pull the middle bit back a tad. You could cut the middle bit out and use thinner ties, maybe... or velcro around the edge. I preferred this, as i can keep the neoprene away from the edge up front.
jeffl do you still have your planet x ones. Would be interested in seeing your take. I got size 12 to fit over size 10 shoe.
I might pop and update on here in a couple of month to see how shredded they got 😀
Posted : 18/11/2016 12:19 pm
