Fitting pannier rac...
[Closed] Fitting pannier racks to bikes with no mounting tabs
Does anyone know of a good rear rack that can be fitted to a bike with no rack mounts?
Posted : 03/10/2011 11:39 am
any rack as long as you use p-clips around the stays etc.
be aware with road bikes that the tubing may be too thin to support the weight of the rack and panniers and consider one of those ones that hangs off your seatpost.
Posted : 03/10/2011 11:40 am
I almost daren't say this, but it's a Pace RC200 .....
Posted : 03/10/2011 11:44 am
those that nag of your seatpost is what I have always used. have had a fair weight in mine [ laptop and heavy books nut nort sure I would trust it for touring duties/weights.
[url=http://]Old Man Mountain[/url] do a rack (I'm pretty sure Tubus do one too) that mounts to the Q/R.
There's also an Aussi/NZ one which sort of straps to your seat-stays. I'll see if I can find a link....
Edit: Found it... http://www.freeload.co.nz/pages/9/Products
Posted : 03/10/2011 11:45 am
have a look at [url= http://www.oldmanmountain.com/ ]http://www.oldmanmountain.com/[/url]
Crikey! I was hoping for something for about 30 quid!
Posted : 03/10/2011 12:02 pm
for £30 get a blackburn rack and some p-clips.
If you use P clips ,still put a bit of lecky tape on the frame ,as grit can still scratch( had this happen on some frames)the seat stays.
Gotta luv that guy on OMM welding in his shorts 🙂
Posted : 03/10/2011 12:13 pm
I got this one that someone recommended on here.
It is adjustable so it works around disc brakes as well. I use P-clips and it is rock solid. Only £13 and arrived next day. Brilliant quality to the tubes.
[url= http://www.bikesyoulike.co.uk/product/5593/TorTec_Apex_Disc_Rear_Rack ]Pannier[/url]
I tried a post mount one and it used to move around under load. Attaching properly to the frame is a huge advantage.
Posted : 03/10/2011 12:27 pm
depending on pannier size you can consider seatpost mount too
Posted : 03/10/2011 12:35 pm
