Fitting new fork se...
[Closed] Fitting new fork seals - errr how??
I imagine there is a special tool to fit fork seals
Trying to get some in and failing miserably......
Any STW garage bodges?
thanks
Posted : 22/11/2015 5:16 pm
Suitably sized socket, but of sink waste pipe, hoover pipe - anything the right diameter and blunt really.
Posted : 22/11/2015 5:27 pm
if in doubt search you tube someone will have a video on there for your make of forks
Posted : 22/11/2015 5:32 pm
have tried with a socket but they just go in crooked
will have another go
Posted : 22/11/2015 5:35 pm
Have you put some lube/fork oil on the outer surface of the seal or on the hole to help it slide on straight...?
Posted : 22/11/2015 5:43 pm
Last ones I did I used my thumbs...... and some fork lube
Posted : 22/11/2015 7:06 pm
if you could do mine you must have ****in strong thumbs!
lowers have been painted - think there is paint inside making them harder
Posted : 22/11/2015 9:33 pm
Unior seal tool off EBay.
Posted : 22/11/2015 9:41 pm
I take springs off,lube outer edge seals or seats in forks,put socket on a corner of something solid with dust seal in it facing up,turn lowers upside down and lean on them to press seals in.Usually works a treat.
Posted : 22/11/2015 9:43 pm
yup tried that - even with my 15 stone they ain't going in!
Posted : 22/11/2015 10:10 pm
 tomd
Strangely the tops off roll on deodorants fit 32mm seals really well. That worked ok but then discovered the huge socket for my VW oil filter fitted better. The proper too is sort of like this, in the size that you need:
http://www.ebay.co.uk/itm/Rock-Shox-32mm-Dust-Seal-Installation-Tool-Reba-Revelation-Tora-Recon-etc-/221877043571?hash=item33a8e70173:g:H7AAAOSwRLZUHUFD
Posted : 22/11/2015 10:23 pm
Pop 'em in the freezer for a couple of hours, bit of grease round the edge and then push them in with just your fingers.
Posted : 22/11/2015 10:26 pm
warpcow - Member
+1 you do have to be quick, they warm up rapidly...
Posted : 22/11/2015 11:36 pm
I like the freezer idea!!
Posted : 23/11/2015 10:41 am
I found the extension bar from my socket set works best. Nice flat end - applies a lot of force in one place. Just work it round and round the seal and goes in bit by bit.
Posted : 23/11/2015 11:48 am
