Okay I am well and trueley stuck, followed the instructions off sram site and have got to the point were I cannot get new cable to go ion? What or how do I get the cable through the housing under the spring?? Thanks
make sure its in the lowest gear 1st off.
have you taken the top carbon cover off?? if so then thats correct.
after that it is fairly easy!
all done but struggling to get the cable into the housing under sring will not turn the bend, if you see what i mean
is it in the lowest gear?? if so it should just slide through with no problems..
Do you mean yoiu're struggling to feed the cable through the hole on the shifter? If so you need to slightly bend the last few mm or so of the end of the cable with a pair of pliers. Should feed thorugh if you do this.
what kind of cable did you manage to get for it?
thanks used giazzrdman method.....cheers
