fitting a hope head...
[Closed] fitting a hope head doctor
4 Users
just attempted to fit my mates new headset, all going swimmingly and i thought to good to be true, i hit a snag right at the end....
fitting the hed doctor, the forks are new and i couldnt get the hed doctor to go in the steerer tube, i gave it a gentle wallop with a wooden mallett and it budged it in a tad, probably about 1/2 a cm in the tube not a full 1cm as recommended.....but then it wouldnt budge at all, so i had to leave it there....it all feels secure, but have i missed something obvious? the video on hopes site the hed doctor just glides in...should i have lubed up the inside of the tube?
and obviously now if he needs to get it out again?
any thoughts appreciated 🙂
Posted : 20/07/2010 6:54 pm
anyone please?? dont want to be responsible for killing my friend 😆
that fact its in and probably 0.5CM in is that enough? the hope video says about 1CM depth before tightening?
Posted : 20/07/2010 7:20 pm
Remove the rubber O ring and it should slip in a lot easier, I've done this on two bikes and it works a treat.
Posted : 20/07/2010 7:39 pm
i think it sliced most of that when it was going in to be honest, i suddenly had a thin slice of black seal in my hand 😆
how would i get it out again now though?? even when i undid the 8mm allen key and made it unclamped it wouldnt budge?
Posted : 20/07/2010 7:45 pm
Don't do what I did and use a metal pole from the bottom to hammer it out, I funked up the head doctor and my steerer WHOOPS.
I had a pain getting mine in first time round however the replacement just dropped right in.
Posted : 20/07/2010 7:55 pm
Has the steerer been cut? The HD should slide right in without any resistance. The usual problems:not having the HD opened out far enough; no grease on the o-ring; misshaping of the steerer from being cut.
Posted : 20/07/2010 8:14 pm
think he's sorted it now, says he just got a thin piece of solid wood and hammered it on top of the hed doctor in the tube 😆 its now easily 1cm in, it suddenly started to move with a few hits 🙂 happy days and my conscience is guilt free 🙂 phewwww! just hope he tightened it up enough now 😆
cheers guys!
Posted : 20/07/2010 8:22 pm
