Fitting a headset w...
[Closed] Fitting a headset with a rubber mallet....
 Pook
[#2369938]
what's the worst that could happen?
Posted : 15/01/2011 1:36 am
It'll go in on the pi$$ & you'll have to make another post asking how to remove it 🙂
Posted : 15/01/2011 1:40 am
you break the mallett
Done loads this way without issue.
Depends on your approach it is a bit agricultural and unsophisticated but it does the job perfectly well
makes sure you hit it square to make sure it goes in square. Usually takes a few hits to get flush. Dont be afraid of a bit of grunt but you are not trying to split logs.
Posted : 15/01/2011 1:41 am
 Pook
I've got it in straight but with about 1mm to go and it won't budge.
Posted : 15/01/2011 1:43 am
6 pints of strong cider first and you won't care 😉
Edit: you forgot the cider....
Posted : 15/01/2011 1:45 am
Hit it harder!
I've never fitted a headset with more than a hammer and block of wood.
If you're a total hamfisted knobber you could get it totally squint and damage the frame. But then you could probably do that even with the right tools if you're enough of a knobber 😉 I got a press just for convenience but did a few with the mallet-and-wood, worked absolutely fine, no different to frame bearings.
I got the press because of getting a head angle reducer headset, which people made a big deal of needing proper tools to fit right. But then it turned out my press wouldn't work with it so I welted it in with a mallet 😉
Posted : 15/01/2011 1:55 am
Wooden mallet is all I've ever used.
Posted : 15/01/2011 1:00 pm
I got one of mine in with about 1mm left and it wouldn't budge. I just did it up and went fro a ride with some tools. Checked it every mile or so and it eventually seated its self good and proper.
Posted : 15/01/2011 2:27 pm
i use the mother of all clamps if it gets sticky.
Posted : 15/01/2011 2:31 pm
It's not overly expensive to buy a long bolt, nut and two washers. Instant press.
Posted : 15/01/2011 8:04 pm
I just use a bit of threaded bar, two nuts and washes and 2 bits of 3 inch square wood drilled through the centre, works perfect every time.
Posted : 15/01/2011 8:26 pm
sprocker - Member
POSTED 19 MINUTES AGO # REPORT-POST
Ditto. Fitted one for the first time this way last week. Simples
Posted : 15/01/2011 8:47 pm
I did the same a few days ago, exactly the same 1MM showing but after doing everything up a few times, it sealed, although I haven't had chance to try it yet.
Posted : 15/01/2011 9:11 pm
Some tralside maintenance tomorrow then chris?
Posted : 15/01/2011 9:15 pm
