fitting a H11 mtb c...
[Closed] fitting a H11 mtb chainset to a roadbike (68mm bb) should you fit all (cont)..
three spacers on the non drive side?
my thinking is :
on a mtb a H 11 chainset normally has a chainline of 50mm
a road triple normally has a chainline of 45mm
so the best way to accomplish this is to fit all the spacers on the non drive side.
comments/suggestions please
btw ..it's for an unfit friend who is surrounded by huge hills!
Posted : 10/06/2010 9:51 pm
I've got the road BB shell spacer tube from a Hope BB if that helps?
£4 posted to you sir,
Alex
Posted : 10/06/2010 9:54 pm
Have you got enough thread on the driveside cup if you fit 3 spacers - also if you fit 3 spacers on one side and none on the other then you'll be a bit offset but I gues you wouldn't notice that - also if you fit 4 your axle wont be long enough?
Posted : 10/06/2010 9:57 pm
alex..not needed thanks
Foxy ...good point re whether there would be enough thread but it would be on the non driveside if there is a problem
not sure where your 4 spacer idea came from?
Posted : 10/06/2010 10:37 pm
Oh I mean't I you wanted the opposite crank in the same position i.e. 3 on one side and 1 on the other i.e. normally 1 L 2 R 🙂
Posted : 11/06/2010 7:38 am
just to update ...
the r/h cup thread is much longer than the l/h and I was reluctant to fit even 2 spacers on the l/h side . Obviously with a mtb chainset and a 68mm bb you have to fit all three spacers somewhere otherwise you can't preload the bearings with the little plastic cap.
in the end I used a road bb (cups 1mm wider) with a spacer either side (not that it improved the chainline!
from my exploits I guess a road chainset has a shorter axle ...anyone confirm this?
blooming compatability problems !!!
Posted : 12/06/2010 9:29 am
A 68mm shell is a 68mm shell, why not use the spacers in the same way you would on the MTB and see if it works?
Posted : 12/06/2010 10:08 am
Dibbs ..it'll work but the chainline won't be very good ..hence my efforts to alter things .
Posted : 12/06/2010 6:45 pm
