Fitting a 24mm cran...
Fitting a 24mm crankset to a Cannondale BB30a road frame
Hopefully this is a simple one but in reality it never is!
I’ve seen, what I think, is a good deal on a new Cannondale carbon (road) frame set (no BB)
Allowing a bit of extra money for a 25.4mm (!!) seat post I have a full build kit of bits … but it’s all Shimano 105.
Can you just fit a BB30 to 24mm bottom bracket? Is there anything special offset wise ( this isn’t an AI frame as far as I know) that I need to be aware of?
I’d ideally like a threaded BSA frame bur paupers can’t be choosers 🤭
All help much appreciated.
Posted : 06/02/2026 7:00 pm
Thanks folks.
Does it make a difference those are all BB30 and not BB30a?
(stoopid standards)
Posted : 06/02/2026 8:00 pm
the threadfit wheelsmfg bb30 to 24 is almost certainly the right answer (but not sure about the asymmetry thing - guess spacers on the NDS required). I have been running one in my roadbike for the last 3 years and it is fault- and creak-less
Posted : 07/02/2026 1:17 pm
I use both the Rotor and Wheels BB30 to 24mm adapters with no issues. There's at least 5mm adjustment via the threading where the two sides join so I can't see the 68mm vs 73mm BB30 vs BB30a being an issue. However, if you're a bit uncertain, just buy that type of adapter advertised for use with BB30a - you'll be grand.
Posted : 07/02/2026 1:48 pm
I’ve got a pair of the bb30 to 24mm adapters as above
make me an offer👍
Paul.sal@btinternet.com
Posted : 07/02/2026 4:12 pm
Thanks again all.
@speshpaul … if I had a BB30 BB to start I’d take you up on that 😊
Posted : 07/02/2026 4:29 pm
FWIW BB30A is asymmetric, so 5mm wider on the NDS so need to determine whether your 24mm crank spindle is long enough to work?
Posted : 07/02/2026 8:12 pm
