fitted new pro II 1...
[Closed] fitted new pro II 12mm axle and wheel won't spin freely???
Found that my Hope pro II axle had snapped so got a new one and replaced it along with the pawl springs that were also knackered. All seemed fine until i rode it round the garden and the wheel wouldn't spin freely when not pedalling, well it would spin but not without the pedals going round as well if I stopped the pedals the chain would gather up.
What could I have done wrong? If I loosen off the maxle a bit it all works fine, but then it seems like the maxle isn't tight enough and before I 'fixed' the axle i could tighten up the maxle pretty tight.
I used this axle http://www.evanscycles.com/products/hope/pro-2-rear-x12-thru-conversion-kit-ec062866#answers
Any thoughts appreciated.
Posted : 20/10/2015 1:30 pm
did you push that rubbery washer/seal thing in all the way?
Posted : 20/10/2015 1:31 pm
Beaten to it.
Posted : 20/10/2015 1:33 pm
Have you left out the spacer between the drive side bearing and the freehub body?
It's only maybe 2mm wide.
Posted : 20/10/2015 1:34 pm
Item 11?
Posted : 20/10/2015 1:38 pm
Everything seemed to push together again properly. I'll take it apart again and have a look tonight, cheers.
Posted : 20/10/2015 1:40 pm
unless that seal on the freehub is clicked into place it will never turn freely.
Posted : 20/10/2015 3:34 pm
 P20
Another vote for the drive seal. I fell victim to this one
Posted : 20/10/2015 3:36 pm
Yep, my first two thoughts on reading the title were
1, freehub seal
2, freehub washer.
Posted : 20/10/2015 3:42 pm
cheers, will pull it apart and check when I get home. Hopefully it's something as simple as that!!
Posted : 20/10/2015 3:45 pm
On my bolt-up I get frerhub drag when the driveside is tight. This is due to it being very slightly bent. Hope it's not that.
Posted : 20/10/2015 3:47 pm
Thru axle does seem a bit more of a tight fit with the new hope axle, maybe it is bent. Bugger, better check that as well!!
Posted : 20/10/2015 4:04 pm
It was the freehub washer, it was still on my work bench!!
Cheers guys.
Posted : 20/10/2015 7:38 pm
Did you fit a steel axle out of curiosity?
Ask as the alloy one is bound to snap again. Hope will supply a steel one if you order via a lbs that deals with hope.
It's the non evo hub, yeah?
Posted : 20/10/2015 9:10 pm
Yeah non evo hub, and i just bought a replacement from Evans. Alu one though. Wheel came on bike I got from a mate so didn't think about going to hope. If/when it goes again i'll drop into the LBS or give hope a call.
Got a QR Hope Bulb rear on my HT which has been faultless for years, this is the first time I've had a rear thru axle.
Posted : 20/10/2015 9:46 pm
ads678 - Member
It's always the freehub washer.
If it happens again, with the breakage, call Hope- they know the part isn't strong enough so you'll get a no fuss replacement, they never asked me for proof of purchase or anything. (they actually sent me 2, the last time, "for next time it happens").
Posted : 20/10/2015 9:50 pm
Cheers NW, that's good to know.
Posted : 21/10/2015 8:52 am
