First time wheel bu...
[Closed] First time wheel build...what 29/700 24h rims?
Picked up some stupid cheap Novatec 24h hubs off eBay with the intention of using them to practice wheel building.
Can anyone recommend some cheap 24h rims for ideally Gravel/light XC?
budget conscious as don’t really need them, just fancy a play at building (hubs cost me a tenner).
could I use 36h and miss every third out? Or is that just plain stupid?
thanks and may the flaming commence 😀
Posted : 04/08/2018 12:21 pm
24 holes wouldn't be where I'd start with a beginner wheel build as you spoke tension needs to be a bit more critical, but in terms of rims you'd probably want something a bit deeper / stiffer to compensate for a lack of spokes, and only 2 cross so something like a Kinlin XR31T. Avoid the temptation to go for spokes like DT Revolutions - they're too flexible and will struggle to get the level of tension needed, so stick to a regular double-butted.
Posted : 04/08/2018 3:13 pm
Thanks Dove. Assuming single butted spokes aren’t worth the savings in cash?
Posted : 04/08/2018 3:19 pm
You're brave building 24h for a first attempt!  I am worried about going from 32h to 28h for my 8th wheel!
If it's purely a learning exercise I'd personally go for the cheapest spokes.
I wouldn't do the 36-1/3 thing if you actually want to ride the wheel.  Aside from aesthetic concerns I have read 24h-specific rims are stronger to reduce flex.
Posted : 04/08/2018 8:43 pm
Butted spokes are the best - they have more 'elasticity' than plain gauge. I'd also stick with brass nipples unless you like to rebuild wheels regularly
Posted : 04/08/2018 9:12 pm
Have a look at Chainreactions Prime rims, and also DT Swiss R460DB. These should both be wide enough for road/cx.
Posted : 04/08/2018 9:48 pm
Thanks all. Went crazy and bought a pair of the Prime CRC rims for a bargain £28. Next up is spoke length? Hmmm?!
Posted : 04/08/2018 10:52 pm
