First road ride
[Closed] First road ride
[#3598310]
Eep! I went out shopping with the Mrs this weekend and ended up coming home with a road bike!
So far after one commute I have learned:
- I need to seriously re-evaluate my braking distances
- the smoothness of Sheffield's roads indicates that the council HATES roadies
- Riding in the drops is bloody scary! Not sure I'll get used to that any time soon.
- acceleration is ridiculously quick, as are hills now!
Anyone have any tips for a newbie roadie?
Posted : 23/01/2012 2:01 pm
Keep on keeping on.
Oh, and MTFU works as a general rule.
Posted : 23/01/2012 2:03 pm
If you thought the braking distances were 'interesting' in the dry - wait until it's wet.
New (good) pads can help though if they really are dire, if you can't lock a wheel then I'd spend a bit of time improving things.
Posted : 23/01/2012 2:05 pm
Pump your tyres up harder. 30psi is only good for mountain bikes, you need 120-130psi. Then enjoy the potholes to their full extent.
Take the peak off your helmet.
When passing other roadies, acknowledge them with no more than a finger waggle - any more upsets your aerodynamics.
Posted : 23/01/2012 2:13 pm
Be amazed at the local guys on mountain bikes who normally give you a cheery wave and nod 🙂 . Now you're on a road bike, they can't even see you 🙁 !
Posted : 23/01/2012 2:17 pm
 flip
You will now observe what all us roadies know.
That the roads are a national joke. In South Staffs where i am we have potholes 4" deep.
Posted : 23/01/2012 2:18 pm
Get out and enjoy, some lighthearted rules [url= http://www.velominati.com/blog/the-rules/ ]here[/url] if in doubt always refer to rule number 5
Posted : 23/01/2012 2:21 pm
Keep at it, it's awesome!
always assume there's more than one car waiting to get past you, plan your braking & gear changes in advance of junctions.
always pay attention to whats going on around you, don't take risks, get some flashing lights.
Posted : 23/01/2012 2:22 pm
Sorry but in the dry there is no difference between a road brake, v brake or disc brake. You need to sort your brakes out if they are not working.
Posted : 23/01/2012 2:23 pm
Get some 25c tyres if you've not already got them (I'm assuming the stock tyres were 23c...). Way more comfy, and can be run lower pressure than 23c, and therefore grippier (I run 90 front / 100 rear @ a bit over, ahem, 12 stone). Win!
Braking from the drops is much more effective - appreciate it feels more committed (it is!) but it's way better than trying to brake from being on the hoods. Hoods ok if you're just trying to scrub some speed off rather than stop.
Posted : 23/01/2012 2:27 pm
STATO - Member
Posted : 23/01/2012 2:30 pm
it will never get easier - just faster 😈
Posted : 23/01/2012 2:32 pm
Hmm seems like i wasnt the only one to impulse buy a road bike at the weekend!
I'm with you on braking distances, do the pads get better once they've scrubbed in a bit?
Oh and the pedals that came on the bike with the strap things, wtf?!
Alas my ex locked me out of the house so I couldnt get alternatives.
It's not so much the brakes as he contact patch with the road, it's way easier to lock up road tyres even with road brakes.
Posted : 23/01/2012 2:35 pm
Loving the tips and the velominati link 😀
It probably is just a case of poor beginner technique for braking, I'm not ready to commit yet! Might take me a couple more rides. Though if it is also a case of useless pads, what's a recommended replacement?
Cheers so far gents!
Posted : 23/01/2012 2:41 pm
road brakes are fine, it's a different way of riding (forget mtbs & discs)
the only time I'd like discs is when a car suddenly stops or pulls out.
straps on pedals are just a cheap option to get started. get some spd's and unlock some free speed
Posted : 23/01/2012 2:43 pm
 Haze
Make sure your limit screws are set correctly, and always carry a spare derailleur hanger 🙁
Posted : 23/01/2012 2:46 pm
Taking the peak off your helmet is a valid tip. It stops you having to crane your neck so high to see under it when on the drops.
sb
Posted : 23/01/2012 2:52 pm
 pdw
Actually, the contact patch doesn't make that much difference. Friction is equal to the coefficent of friction multiplied by the normal force (i.e. the weight on the tyre). Contact area doesn't come into it. In the real world there are other factors you need to consider, but the contact area isn't as big a deal as people make out.
On a dry road, the limiting factor to how fast you can stop has nothing to do with grip anyway - there's enough grip to put you over the bars. So the limiting factor is how hard you can brake without the back wheel lifting, which is down to geometry and weight distribution.
Posted : 23/01/2012 2:55 pm
Big different in brakes as well, my winter bike came with Tiagra which seized solid in about 4 months, replaced with 105 which are marginally better, they've not seized, not really any more powerful though.
Summer bike has Dura Ace 7800s which have had new cables about 3 times in 8 years, and are absolutely fantastic, bags and bags of power and feel.
Posted : 23/01/2012 2:58 pm
 Haze
and your Camelbak will get in the way...
Posted : 23/01/2012 3:02 pm
dont wear a camel pack 🙄 - oh and shave your legs or you'll never progress!
seriously though get some lycra with a padded arse & some mitts with padded palms
Posted : 23/01/2012 3:05 pm
@B_leach
welcome to road bikes!
every mountain biker should have one, they are great for going out riding (to keep fit and get your cycling fix) when the weather is filthy and you are fed up of spending 45 minutes cleaning your mountain bike and kit after every ride!
its great to own different kinds of bikes, have fun with your road bike 🙂
Posted : 23/01/2012 3:07 pm
 Del
i have cheap-5hit tektros on my stock, 5 year-old langster, and that stops just fine. try cleaning the rims with IPA or something. they may have something on there to stop them discolouring or something.
Posted : 23/01/2012 3:09 pm
Enjoy a new line in Christmas present idea's, as I did this year....
...oh and be careful, its strangely addicitive.
Posted : 23/01/2012 3:13 pm
pdw - Member
Sorry but this post contains a significant quantity of bovine faeces.
What you say about friction and contact area is correct for hard materials only , but does not apply to rubber. Rubber on tarmac - more surface area = greater grip.
Secondly, more grip does allow you to stop quicker for several reasons. First you can brake harder with the rear wheel, second in reality, on my road bike at least, there is often not in fact enough front wheel grip to throw you over the bars, even in the dry (unless you ride like a muppet and have your weight right over the front).
Braking distances are significantly longer on my road bike compared to my mountain bike, even on a smooth dry road, and it's nothing to do the the brakes, and everything to do with grip.
Posted : 23/01/2012 3:22 pm
Every time ive had to do an emergency stop on the road (be it on an MTB or skinny road tyres) ive ended up doing the last few meters balencing on the front wheel. Are you telling me if i got fatter tyres i could somehow stop faster without going over the bars? Once youve got a certain level of grip and braking force adding more of either will do nothing, the deceleration of a bicycle is restricted by the fact your COG is above the level of the front axle.
Posted : 23/01/2012 5:03 pm
 pdw
The rule is not limited to hard surfaces, but as I noted in my previous post, that equation isn't the whole story either. But the fact is that skinny road tyres on dry tarmac have shed loads of grip. If you don't believe me, just look at pros cornering:
Secondly, more grip does allow you to stop quicker for several reasons. First you can brake harder with the rear wheel, second in reality, on my road bike at least, [b]there is often not in fact enough front wheel grip to throw you over the bars[/b], even in the dry (unless you ride like a muppet and have your weight right over the front).
You seem confused between front wheel grip and braking power. Are you saying that your front wheel will skid before your back wheel lifts? Or are you just saying that you don't have enough power in the brakes to lift the rear wheel?
Assuming that you have enough braking power (which you may or may not do) and enough grip (which you will do in the dry on any bike other than a recumbent or tandem) to lift the back wheel, then being able to "brake harder with the rear wheel" is irrelevant. The fastest way to stop is to brake to the point that the rear wheel is just on the edge of lifting, at which point there's no grip available for braking with the rear wheel anyway.
Posted : 23/01/2012 6:50 pm
Anyone have any tips for a newbie roadie? (in sheffield)
a 28t cassette will help a lot*.
28mm tyres at 60psi take the edges off the potholes.
the spiced apple cake in elliots cafe, hathersage, is lovely.
there's some good riding on quiet swoopy roads around strines.
(*especially when the spiced apple cake is sitting heavily in your stomach, and you're riding up past the scotchman's pack, wishing you [u]had[/u] listened to me about the 28t cassette, but [u]hadn't[/u] listened to me about the heavy 28mm tyres...)
i've recentl found clarks to be good enough, swissstop are meant to be very good, buy C-reaction haven't delivered them yet...
Posted : 23/01/2012 7:35 pm
All the things you're worrying about? just don't
Leave the bike as it is. Leave the 23s on, 100 each end is plenty.
Yeah, remove the peak but don't replace it with a cotton one.
Be humble.
Posted : 23/01/2012 8:41 pm
the yellow jersey guide to the tdf is a good read.
as is- the rider,krabbe.
and velocio,though I've only read of him.nothing by him,except his commandments.
http://thebikeshow.net/velocios-7-commandments-for-the-wise-cyclist/
fiddle with everything.bar height,reach,saddle height,setback.but one thing at a time.and about 2-3mm per adjustment.keep your bars high,then lower them as you feel better.get a fit done.it's a good starting point.
have fun.
Posted : 23/01/2012 9:41 pm
this^ ignore the MTB sensibilities. in the same way that roadies don't know better with mtb setup don't expect mtb'ers to know better about roadbikes.
naturally if you are a cyclist you know how to do both 🙄
23's and a psi to suit your weight. (67kilo's so i only use 85-90 front/90-100 rear)
Posted : 23/01/2012 9:49 pm
Make sure you count your sprockets before each ride....
Posted : 23/01/2012 9:52 pm
This may be of use, particularly the bit about [url= http://www.bikeradar.com/news/article/bicycle-tires-puncturing-the-myths-29245/ ]rolling resistance[/url] (one of the reasons I like 25c tyres, not just comfort).
Posted : 23/01/2012 10:29 pm
Bollocks. You can spout all the theory you want, still bollocks.
Posted : 23/01/2012 10:35 pm
As the highway code stated ( I've no idea if it still does)
Stopping distances increase with speed and in the wet
Now that is a fact
Enjoy your Road bike and when the trails dry out a bit amd the days get longer you'll find your a lot stronger for it.
Also I can now report back to QoS that boys also struggle to adapt to drops so thanks for that 🙂
Posted : 23/01/2012 11:39 pm
Haha, I've had the spiced apple cake recommended to me by a colleague just this morning! I may have to take my first "leisure" road ride out to Hathersage on Sunday...this is indeed a slippery slope.
For the moment, I can't quite bring myself to remove the peak from my helmet. There's a little voice inside my head that shouts "NOOOOOOO, you are a mountain biker"
Posted : 24/01/2012 2:16 pm
ignore that voice - he's an idiot.
Posted : 24/01/2012 2:22 pm
I thought roadie loved bending over 😉
Drop bars CX buke now that is bloody scary!
Posted : 24/01/2012 2:23 pm
"For the moment, I can't quite bring myself to remove the peak from my helmet. There's a little voice inside my head that shouts "NOOOOOOO, you are a mountain biker" "
Seen any mountain bike racers lately? Not many peaks around on those boys. Most mtb'ers down here ride a bit of both and wear one helmet for both.
It's just a peak.
Bet your legs are shaved by June 🙂
Posted : 24/01/2012 2:38 pm
keep at it mate it will be worth it when you are dusting your fellow mtbers on the trails 😉
the traction argument is seriously boring! 🙄
be prepared to become obsessed with average speeds
Posted : 24/01/2012 2:41 pm
For me over the last 6 months the road bike has been used more than my mtb"s, family life,home and work have been too usy to find the time to drive 35 miles to the forest, but i can wheel out the roadie and have a couple of hours to keep my fitness up and most importantly, ride a bike.
and the lovely Wife, has bought me a nice shiny new Cannondale Supersix for my 40th! which is sitting doing bugger all at the moment as i have to get over a Cornea transplant first............
Posted : 24/01/2012 2:48 pm
Just got myself a road bike after about 5 months away from it, loving it again! Ride the road bike every day, only have the time and money to mtb on proper trails about 2-3 times a month.
I think you get used to the drops quite quickly. I still need to get some reach adjuster pads though, wish they had an easier way to adjust them like you get on normal brake levers. Only thing I'm finding is that I'm getting bad wrist pains but I think my wrists may just be nackered from a mixture of whistler braking bumps and forks with terrible small bump sensitivity!
Posted : 24/01/2012 3:13 pm
!. Swissstop Greens or Koolstop Salmons are both good pads ime, wet and dry. Road brakes seem to vary a lot, I had some cheap Tektros on my first road bike that were truly awful. Good road brakes with decent pads will slow you down fast. If they don't there's something wrong.
2. On the bars front, compact drops - they're closer to the tops - are a lot easier to use, which means you'll actually use them more. FSA do some cheap ones for about 30 quid, which are fine. Hardened roadies will sneer, but these are people who think you'll go to hell if you don't wear white socks.
3. People are obsessed with the idea that they need 120psi to go fast. In reality, 120psi feels fast because the tyres are rock solid so you feel every bit of roughness on the road surface. Depending on how heavy you are, you can run a lot less - say 90-100psi - without losing any speed at all, but they won't feel as fast. This is straight from someone who ought to know because they're a veteran road bike journo.
4. What other people have said about 25s rather than 23s - Conti GP4000S in Black Chilli are amazingly grippy wet and dry. Cheap and nasty tyres are just scary.
5. This all works for me, but I'm just a normal sort of cyclist. I absolutely concede in advance that anyone who disagrees with me is probably correct.
Posted : 24/01/2012 3:33 pm
I love my Road bike, I have Lycra, but I will not shave my legs....
I bought a new Helmet minus peak for the road, but My MTB one is now broken so I just use the Roady one for everything now 😉
Posted : 24/01/2012 3:56 pm
