Hola - Putting this one out to the hive mind as I'm not having much luck so far...
I'm looking for some replacement gravel forks - as the aluminium crown and carbon legs on my 7 y/old pair are doing their best to part ways. (Nice crack around the top of both fork legs where they join the crown! Sadly, it's very much out of warranty).
Finding replacements of a similar spec is proving to be a bit tricky, so if anyone has any pointers...
400mm a/c
Quick release
Post mount brake
Mudguard mounts
Clearance for 40mm off road tyre, or slightly smaller road tyre with mudguards
Can be carbon or aluminium, around £100 from a brand/source that can be trusted 😉
Thanks in advance!
The Alpkit ebay shop have a few available if you like the colours. Might need an adapter to change from 12mm to QR though
I owe you a beer! I've been looking for new forks for my gravel bike as my current ones have no bosses on the legs for attaching stuff. Those Alpkit ones are perfect and a crazy price! There's one less sage version available now!
I bought some Surly Straggler forks for my gravel bike. Heavy but comfy . I think they meet your spec
@BoardInBob I reckon you or I must have had the last pair.
That colour though. Next question: what's the best way to remove paint from carbon fibre?
Glad you got sorted!
@stevemorg2 - fine work, Sir! I'd not thought about thru adapters for the front hub, turns out Fulcrum do a set for a tenner so job's a good'n. 5mm shorter than current forks but I doubt I'll notice the odds when riding. I think a few of us are going to end up with some 'challenging' colour combos but at that price it's rude not too 🙂
@amthill - not a bad call either, although the ones I've found were straight rather than tapered headtube...
I was sure it said 'Last one' when I ordered but they must have found a few more 🙂
