Fat front wheels......
[Closed] Fat front wheels.....what hubs are you using?
6 Users
As per the title, what hubs do you use if it is a 135mm non offset spacing? Do you reckon this might work?
[url= http://www.singletrackbikes.co.uk/product/7726/Atomlab_Pimp_Single_Speed_Rear_Hub ]single speed hub[/url]
Posted : 29/05/2011 6:17 pm
Xt rear hub here .
Built it arse from tit though
Ya wanna try it ?
Posted : 29/05/2011 6:41 pm
I used a DMR Revolver.
Posted : 29/05/2011 10:32 pm
I'll be using a SSC SS hub.
Posted : 30/05/2011 6:58 am
Chub ss hubba
Posted : 30/05/2011 7:10 am
terry, I would but would need to borrow forks too. And thanks all for the info I guess the ones I linked too would be fine then.
Posted : 30/05/2011 4:17 pm
It depends on what fork you're going to use.
If you're using an Enabler or Pugsley fork you'll need a ss rear hub as it's 135x10mm. But if you're using a Jones, Vicous Cycles, Fatback fork you'll need a fatbike specific hub that's 135x9mm spaced. Jones, Phil Woods, Fatback will be able to sort you out with this option.
BTW. Hello Dan. 🙂
Posted : 30/05/2011 5:41 pm
Hmmm. damn. Thanks stu. Was contemplating planning a potential jones build. Need to continue saving I guess.
Posted : 30/05/2011 9:44 pm
