Fat bike calf rub?
[Closed] Fat bike calf rub?
Is this a problem? No one has mentioned it .
I had a Superlight on which my calves would hit the swing arm when pedalling . This meant I rode like John Wayne and did myself no end of mischief.
Surely a big fat wheel means wide seat stays and thus pedalling problems?
Posted : 28/12/2015 6:06 pm
Bb is wider isn't it ? Some suffer a little but I've got two fatties and neither one is noticeable.
Posted : 28/12/2015 6:09 pm
Hasn't been a problem for me, though I do pedal like a duck and get terrible chainstay rub even on normal width frames.
The Rose Tusker does look like it might be particularly wide near the calfs though
Posted : 28/12/2015 6:10 pm
But it also involves a wider bottom bracket so I notice no difference (Pugsley rider). I'd guess you would be less likely to have a problem either with a 170mm rear (or135) or with an Ice Cream Truck which has an even wider bottom bracket. Best to try some.
Posted : 28/12/2015 6:11 pm
With Fatbikes getting cheaper and cheaper (Voodoo and Dune) an impulse is getting more likely.
The calf rub was one thing holding me back.
Posted : 28/12/2015 6:22 pm
Got a Tusker and dont make contact,I use flats and because it was new tried not to get heel rub and settled in to a comfortable position which just feels right now.Its an each to their own really but no one I ride with has ever mentioned it (4 fat bikers). Give it a go .
Posted : 28/12/2015 6:29 pm
I have big calves - always rubbed on my 26 and 29er bikes of the past. Not had any issues with my Fat bike at all.......
Posted : 28/12/2015 6:31 pm
100mm bb axle on many of them means calf rub is somewhere near impossible - the width is weird in itself when most of your other riding is on the road, though
Posted : 28/12/2015 6:33 pm
^ I know the existance of a single fat bike without a 100mm BB myself.
No calf rub for me with an OO fatty.
I can't wear long baggy shorts tho as they sometimes rub on the tyre, but that's not the end of the world.
Posted : 28/12/2015 7:32 pm
My frame has clearance for 5" tyres, runs a 120mm spindle crank with a 197mm rear and no clearance problems - just like the fatbike q-factor myth, it doesn't exist in reality.
Posted : 28/12/2015 7:44 pm
The odd time I touch right side on my Trek but that has that new wider axles now.
Posted : 28/12/2015 8:10 pm
Not heard of a Pugsley ?
Posted : 28/12/2015 8:14 pm
Yep, it was one of the first fat bikes I knew of, I'm pretty sure they used a 100mm BB
Posted : 30/12/2015 4:21 pm
Pugsley is a 100mm BB
zippy, have you flippin bought one yet?
Posted : 30/12/2015 4:23 pm
Mainly no. I did put a Dune in the checkout to see if that spend 80 code worked. Then I get a text saying it's ready for collection in an hour. Next my phone rings and the man says I can collect now!
I will get one but ideally want it to go through the shop.
As mentioned elsewhere our bank is closing and our nearest one is 2 miles away in a town centre. We need to get change every day so I either go on the bus or our accountant finally agrees that a bike is a justifiable expense.
Posted : 30/12/2015 4:45 pm
