Fastener help - wha...
[Closed] Fastener help - what is what I want called, and where might I buy it?
I want to mimic seatstay rack bosses.
I want something like a T nut or a T bolt? With 2 long tabs so I can secure at both ends to a tube with jubilee clips. Frame has wishbone stays, so I'd probably clip one to each side of the central strut with the same jubilee clips.
Something like this (silver bit) but with longer tabs
Either nut or bolt would work, but perhaps bolt would be better - bolt length not so critical that way.
I've looked at braze-on adapters but the ones I've seen have the threads at the wrong angle. unless there's a type I've not seen?
Any of that make any sense at all?
Cheers for any pointers!
Posted : 07/04/2015 12:13 pm
Surely a [url= http://www.evanscycles.com/products/tortec/p-clips-ec006759 ]P-clip[/url] would be far better for this? It's what they're designed for.
Posted : 07/04/2015 12:16 pm
I was thinking the same as njee, p-clip with the bolt straight through.
Edit, if you're zip tying slide bolts to a frame, it'll make a mess of the paint.
Posted : 07/04/2015 12:23 pm
Huzzah! I had high hopes for a reply like that.
I could have worded it the same and said "Fill in the gap!"
Cheers Nick.
Posted : 07/04/2015 12:25 pm
Pleasure! Your LBS may even have some - we had a whole bucket of different sized ones for different stays.
Posted : 07/04/2015 12:28 pm
Would it work to use something like a seatclamp with built in rack mounts:
Posted : 07/04/2015 1:33 pm
mlc - even better, I need a new clamp anyway. And I've seen those before. Durrr...
nick - LBS is a small box commuter Evans, they never have anything just-in-case-y
Posted : 07/04/2015 2:01 pm
