I've laced up and tensioned & trued my first rear disc hub build. I haven't dished it yet but the rim seems way off from centre in the truing stand. Whenever I've built rear wheels before (non-disc) the drive side spokes have always been shorter than the non-drive side and the wheel hasn't usually needed a significant amount of corrective dishing.
When I put the (correct) dimensions for the disc hub build in several spoke calculators they all came back with the drive side spoke lengths a couple of mm's longer than the non-drive side.
Is this normal for rear disc brake hubs?
Just looking for some reassurance before I dish the wheel in the bike frame tomorrow and pull all the eyelets out of the rim ๐
If the NDS flange is bigger then it may have longer spokes.
In any even unless they are way out it'll prob be OK - just tighten the DS until it's roughly centre then work from there.
Just thought about it and yes it has!
Now why didn't I think of that?
Cheers Al, I can sleep soundly tonight ๐
the last few wheels i have built (hope hubs) have had the same length spoke on l/r of the rear (same as 1 side of front too)
๐
Sorry NDS flange larger means shorter spokes ๐ณ
I read it as you meaning the larger spokes being on the drive side, so no worries.
Here's another interesting spoke fact...
The front & rear, left and right, hard-to-get-hold-of, flat spokes on my old Mavic Crossrides are all the same length. I've got several spares but haven't had to change one yet ๐
