Extending ground fl...
[Closed] Extending ground floor - when ground floor above ground level
[#3928539]
Looking at a house, the ground floor is actually above ground and there is a lower ground floor. In the lower ground floor, the ground level is about mid height of the floor.
How do you extend the ground floor?
Posted : 30/04/2012 4:39 pm
Posted : 30/04/2012 4:54 pm
Expensively
Posted : 30/04/2012 4:58 pm
Pretty easily. You need to speak to someone competent.
Posted : 30/04/2012 5:02 pm
Being fuilly STW qualified and having absolutely NO building knowledge i would guess at digging down to below lower ground level and laying new foundations then building up from there.
But I think IHN's explanation my be more accurate 😉
Posted : 30/04/2012 5:04 pm
Depends on a number of factors really e.g. the ground conditions / soil type, size of extension, type of construction. You may be able to use normal strip founds & trench fill, alternatively, a ground bearing floor slab or even mini piles. Best really to speak to a structural engineer.
EDIT - just re-read your post. A ground bearing slab probably not an option due to the existing ground level.
Posted : 30/04/2012 5:23 pm
Sorry, this being STW I only wanted responses from people with absolutely no building/architecture experience (like me).
Posted : 30/04/2012 8:08 pm
My solution was to do it on stilts.
Just wanted all options in my head so I can appear clever when I meet architect tomorrow.
Posted : 30/04/2012 8:10 pm
 aP
You could have a lightweight timber frame on columns. Tell your architect you want pilotis.
Posted : 30/04/2012 8:48 pm
Hang it off skyhooks. Its a new technology but very effective, your architect may not have herd of them so you may have to press the matter.
Posted : 30/04/2012 8:54 pm
Fine, be like that if you want 😉
Posted : 30/04/2012 8:59 pm
