Exposure Joystick -...
[Closed] Exposure Joystick - how long to recharge with a mains charger
[#1443343]
Got given an old one - 2006/7 model year? Just got a mains charger from USE and re-charging it now.
It's sitting underneath my desk, flashing every second or so which guess means it's re-charging? How long's it likely to take? It wasn't flat when I started.
+ how long will it last at full beam on a full charge? I'll be using it for commuting - 20-30 mins at a time
Posted : 24/03/2010 5:38 pm
It's charged when the light on the charger turns green, about 3hrs
Posted : 24/03/2010 5:50 pm
4/5 hours to 90 capacity & a further hour for the last 10%
you cannot overcharge these as the circutry even on your model will not allow it.
also the litium ion battery,s pcb board is set so you don,t need to let the battrey run out before you charge it.
one thing to note though litium ion batterys must be charged once a month for the full cycle even if not used.
Posted : 24/03/2010 9:21 pm
