Estimated weight of...
[Closed] Estimated weight of a Scandal 29er???
Thinking of one of these under a cycle to work scheme. Its the standard model that on one are doing for £999 inc carbon forks etc. i.e. the one you'd get if you didn't amend any of the build options.
Obviously this is spec dependent, but any ideas as to how much this would roughly way?
Posted : 15/03/2010 6:40 pm
26 - 27lbs at a guess
Mine is 25.5, but has quite a weight saving using full XT and Stans arch rims/ZTR Hubs and tubeless, Thomson post and carbon bars. That said, it has Reba forks which will add a couple of pounds. The weight is in the On-One wheels, not knocking them, they are a bargain and very strong, but not light
Posted : 15/03/2010 6:48 pm
my scandal 29er single speed is just under 22lbs with rebas on the front and 2.2 tyres at the moment. and can go to just under 20lbs with rigid carbons on
Posted : 15/03/2010 7:40 pm
Mine weighs 9.9kg
Posted : 15/03/2010 9:31 pm
