errr....can i save ...
[Closed] errr....can i save oily pads & how do i shorten the brake hoses?
[#501484]
1 - shimano slx hoses come up waaay too long.
only found that out after fitting.
i've got a set of proper cable/housing cutters, will they do?
2 - also i hadn't tightened the bleed valve up properly on the back so each time i braked oil spat out.
thought about putting the pads into the oven or roasting them on the hob to try and rescue them.
reckon it'll work?
cheers
J
Posted : 25/04/2009 7:12 pm
You might be able to save the pads with a mix of scrubbing them with detergent / solvent, burning them over a flame and sanding them down. You can destroy the bonding to the backplate doing this and you have a better chance with only light contamination
Dunno what the SLX hoses are made of but I shorten hope ones with a pair of pliers so I don't see why not. You may well need new olives to reconnect them tho
Posted : 25/04/2009 7:23 pm
already swapped the hoses over. how do i get the old olives out and prehaps re-install them?
otherwise, where do i find olives without going through a really expensive, ****y, franchise bike shop?
Posted : 25/04/2009 7:28 pm
Saucer+meths+pads+match = good chance of recovering them. Has worked for me previously with DOT on pads.
Cut hose with anything handy, have used snips, cable cutters and stanley knife.
Posted : 25/04/2009 7:35 pm
try your lbs for a new compression olive. they will probably have a few shimano ones laying around from all the fitting and servicing they do.
got a couple of avid ones off mine for pence.
Posted : 25/04/2009 7:56 pm
