Enve AM rims on a H...
[Closed] Enve AM rims on a HT .. "too stiff"? (alternatives)
[#6040659]
My current kit-crush is for a set of wide 'AM' style rims for my Yelli Screamy (29er).
Anyone running these on an HT? Is there any mileage in the rumour they're "too stiff" for a HT?
and while we're here ... any alternatives that avoid the need to send the kid out to work and cut the cat's rations? (again).
what I'm looking for is light wide (24-25mm internal) 29er rims that can run tubeless and support wide tyres with a nice profile. Yeah I know about Flows, thinking lighter. I actually don't need super strength, I'm not a hucker.
am a bit dubious about the Chinese options - wheels have to be safe.
ta.
Posted : 16/03/2014 1:13 pm
I'm not a hucker but still managed to wear out a Flow on a 26" hardtail. What's on there now?
Posted : 16/03/2014 1:18 pm
me? currently I have Arch Ex. I want wider without a big weight penalty. On a 29er, rotational mass matters. As it does to middle-aged giffers too.
Posted : 16/03/2014 1:19 pm
"Anyone running these on an HT? Is there any mileage in the rumour they're "too stiff" for a HT?"
Been reading too many magazines recently ?
Posted : 16/03/2014 1:29 pm
light bicycles 35mm hookless?
Posted : 16/03/2014 1:36 pm
No such thing as too stiff with a rim. When you've got a tyre with 60mm of travel on there, you won't notice the difference between 1mm and 2mm of flex in your rim (made up figures - I suspect it's not even that much).
Posted : 16/03/2014 1:51 pm
Just use a thinner spoke in every other hole...
Posted : 16/03/2014 2:03 pm
I have had then on my Jones, all my fillings are still in place and they're pretty marvellous.
Posted : 16/03/2014 2:34 pm
Logically this makes sense to me.
Posted : 16/03/2014 3:00 pm
Posted : 16/03/2014 3:29 pm
If you don't fit any tyres, then yes, they might be too stiff. Otherwise, get on it! 😉
Posted : 16/03/2014 4:01 pm
wish you hadn't said that
Posted : 16/03/2014 4:10 pm
i recommended chinese carbon and i have Enve,
Posted : 16/03/2014 4:13 pm
If you think you can discern "too stiff" as a quality in a rim, as opposed to a wheel, with spokes, attached to a bike, with stays, and suspension, all encased by a big rubber tyre, I think you're talking cobblers.
Posted : 16/03/2014 4:25 pm
 iolo
At 800 pounds each (or however much they are now) if do you buy them I'm sure you'll convince yourself they're amazing
Posted : 16/03/2014 4:29 pm
Thumbs up for chinese carbon from me !!!
Posted : 16/03/2014 5:07 pm
How about those rock guards [s]rimz[/s] rims? They were about 300 quid a pop I think. Widths looked sensible.
Posted : 16/03/2014 5:11 pm
^^ just rebadged light-bicycles no? or some form of chinese carbon.
Posted : 16/03/2014 5:36 pm
WTB KOM 23mm internal and 448g
or the frequency i23 + i25 with a bit more weight
Posted : 16/03/2014 5:46 pm
Another here for LB hookless - and I too run Enve's.
Posted : 16/03/2014 5:51 pm
Pretty sure Rock Guardz ones are from Carbonal rather than LB.
Posted : 16/03/2014 6:20 pm
It could easily be emperor's new clothes but I stuck an LB rim on the back of my hardtail, I think there's a difference- even with a 2.3 rear tyre. No idea if I'll still believe that in 6 months.
If you watch slomo video sequences you sometimes see wheels doing a hell of a lot more than you'd expect, this isn't the best example but skip to 50 seconds on this:
Posted : 16/03/2014 8:50 pm
HI,
I have had good results with some earlier Reynolds carbon 29ERS (the all black ones)
About as wide as a Flow but lighter(my wheelset came in at 1600 grams)
They seem to have a good amount of ping over the rocks and smaller obstacles,but never to stiff or flexible.
A few sets going cheaper at the moment as a newer model was released a year or so back.
Original price was about 1500 but have seen some new ones selling on Ebay for about 800.
Thanx,
Max
Posted : 16/03/2014 10:37 pm
The LB AM internal width is 23mm they say, only 2mm more than my Arch Ex. Not sure it's worth switching to gain just 2mm.
Enve AM are 24mm, so it's a moot point perhaps. 1/2 mm each side is nearly a measuring error.
For comparison, Stans say Flows are 25.5mm internal.
Posted : 16/03/2014 11:08 pm
 br
[i]Yeah I know about Flows, thinking lighter. I actually don't need super strength, I'm not a hucker.[/i]
Crests?
Posted : 16/03/2014 11:14 pm
They're doing a 35mm (30mm internal) hookless rim now too I believe.
That's what I'd have. I've got the 'normal' hookless 29er rims and very impressed.
Posted : 16/03/2014 11:15 pm
[quote=Northwind ]If you watch slomo video sequences you sometimes see wheels doing a hell of a lot more than you'd expect, this isn't the best example but skip to 50 seconds on this:
br />
The bit where the tyre's squirming all over the place? I'll grant that you do get lateral flex at the rim in a built wheel (which there might be in that video, can't really tell to be honest), but that's not the same as vertical flex, which is what the OP seemed interested in. I agree there probably is an advantage to stiffer.
Posted : 16/03/2014 11:21 pm
[quote=njee20 ]They're doing a 35mm (30mm internal) hookless rim now too I believe.
I'll try again here as no answer on the other thread - I don't suppose anybody has some of the 35mm hookless and could give an idea how wide tyres come up on them (preferably compared to a Flow if anybody has experience of both)?
Posted : 16/03/2014 11:23 pm
Will do this week when mine arrive hopefully aracer. Currently running mkii 2.2, purg 2.2 and saguaro 2.2 but still toying with a 2.1 tho maybe I'm expecting a bit to much extra girth.
Posted : 16/03/2014 11:50 pm
aracer - Member
No, the bit where he clouts it off a rock and you can see the wheel deflecting inches.
With hardtails, it's definitely not just about vertical- anything that takes force out of a hit takes strain off the bike/rider. My old Traversee used to walk about all over the place- a lightweight wheel in the first place even before I ruined it 😳 But it all helps.
Posted : 16/03/2014 11:55 pm
I saw some slow-mo enduro footage recently where the front wheel deflected sideways so much I expected it to taco but it just sprung back. It's possible it's the same as the link above, but I don't view video away from my wifi.
On a tangent, it was during a profile of Jared Graves who has been racing XCO at the Australian National Series and Champs as training to try and win the Enduro World Series. I think they said he won the series and he only came 2nd to Dan Macconnell (sp?) in the champs. Phenomenal!
Posted : 17/03/2014 7:23 am
Have a look at the new American classic wide lightning's.
Posted : 17/03/2014 9:22 am
LB say "There is a new kind of 29er hookless rim (35mm outer width & 25mm depth) with new process. It's also tubeless-compatible. The weight is 420 /-15g(AM version) and the price is USD180/pcs."
http://www.light-bicycle.com/all-mountain-29er-carbon-mtb-wheels-clincher-tubeless-wheel-ready.html (reviews)
what does 'hookless' mean in this context? (their attachment not included on web).
[b]EDIT[/b]: answers own question here: http://www.light-bicycle.com/hook-less-control-carbon-29er-rims-is-ready.html
am a bit dubious about how that retains the tyre safely!
Posted : 17/03/2014 9:28 am
Pretty sure you're thinking of this one - EWS roundup.
Posted : 17/03/2014 10:17 am
mattjg - Member
Specialized are doing hookless too now fwiw, apparently the process more or less went:
"Why do rims have bead hooks?"
"Durr, rims have bead hooks!"
"Yeah but why?"
LB seem pretty confident, I got an assurance that there's no drawbacks before I ordered mine (haven't got them yet to try)
Posted : 17/03/2014 10:48 am
I presumed rims had bead hooks to give the tyre beading something to hook to. Shows what I know.
Posted : 17/03/2014 11:22 am
Yes, bo-ing, about 4.05 in andyrm, although I just saw it in a short sequence during the National Champs coverage.
Posted : 17/03/2014 11:36 am
First couple of rides on my hookless rims I wasn't totally trusting of them, but they've been absolutely fine. Running 25psi in 2.25" Rons.
Posted : 17/03/2014 11:54 am
@njee ta, tempted, close to my set up.
good fun watching that wheel ping, it almost looks like the rider booted it back in shape.
Posted : 17/03/2014 1:07 pm
For some reason they aren't making a 26" version of the 35mm rims 🙁
Currently, there is no 35mm wide 26er hookless rim. But we have 33mm wide 26er hookless rim
Posted : 17/03/2014 1:08 pm
The 33mm is still pretty generous- wider internally than a Flow Ex and the hookless design should mean the tyre's more "round" so a little higher volume. Making molds is expensive so tbh I'd be a bit surprised if they produce any more sizes for 26 inch.
Posted : 17/03/2014 1:35 pm
Ah so the flow is 29.1 outer and 25.5 inner
Posted : 17/03/2014 1:53 pm
and the LB 33mm
Posted : 17/03/2014 2:21 pm
yowser that LB 33w is 30mm deep. does that mean the wheel builder uses shorter spokes?
Posted : 17/03/2014 2:26 pm
If we're talking rim deflection this is a great example:
Followed by:
Now I doubt it was perfect afterwards, but it seems you can deflect a carbon rim quite a bit and it'll come back!
Posted : 17/03/2014 2:32 pm
