Engineer types: Wha...
Engineer types: What are these called?
These little brass (?) inserts for screws:
I need to know what they are called so I can order them from somewhere. I have a raw 3d printed seatpost mount and I assume I need to tap these into the material so I can screw on the Garmin quarter turn adaptor
TIA
Posted : 17/12/2025 9:48 pm
 K
Heat set inserts
Posted : 17/12/2025 9:49 pm
Or heat fix insert nuts. It's quite common in 3D printing land to balance them over the hole then heat them up by pressing a soldering iron against them, waiting for them to get good and hot and then pushing them in.
With 3D prints with the normal amount of infill a conventional insert nut for wood does the job too.
Posted : 17/12/2025 9:55 pm
Thanks folks!
I'll probably be back for more advice soon 😃
Posted : 17/12/2025 10:02 pm
I’d google ‘threaded insert’ or ‘knurled insert’ there’s bajillions about.
Posted : 18/12/2025 1:13 am
https://www.tappex.co.uk/
Posted : 18/12/2025 8:40 am
OP Name checks out.
Posted : 18/12/2025 9:26 am
Just popped in to post the Tapex link, beaten to it!
Posted : 18/12/2025 1:44 pm
