Ok I'm feeling left out. I have a Windows Phone and Strava have said they will not be releasing an App for it.
So can I download my Endomondo workouts in to Strava to see how good I am against the rest of the world?
Ta
yes.
Export function underneath the workout details.
export them all to a gpx file in endomondo
attach all the gpx files to an email
email them to the address that strava tells you when you try to add a gpx
yes
select the route on the endomondo website, hit export and select TRX file.
on strava
go to upload activity, select from computer and select the file you have just saved from endomondo.
hey presto you are now addicted. 😀
Thanks will open a Strava account
Good to see conflicting advice on how to do it on STW 😆
mine and andys both work, there are 2 ways to import routes to strava 😀
The way I did it was to use a Facebook "Activities" app which recognises Endomondo as an import source. It syncs all of your Endo workouts into the Facebook app from where you can generate a zip file containing all the gpx files. You then Email Strava ( upload@strava.com from the Email acct you're registered with at Strava ) all the GPX files and they're automatically imported into your Strava acct.
Using this I migrated about 50 tracks in one shot 🙂
The Facebook Activities app was a bit flaky on doing the Endo sync but once it started then it got them all.
Allthe - I think I will give that a try at some point.
Quite suprised myself so far, top 5 for a lot of my local trail
Got to improve 😈 only 35th around Sherwood Pines
Hi,
Me and a friend just released a 3rd party app that supports tracing and upload directly to strava.
If you want to check it out, you can pick it up here:
[url= http://www.windowsphone.com/en-us/store/app/strava/833233a2-8d06-4f43-aa17-cecb3555b03c ]Strava app for Windows phone[/url]
Also, we set up a wordpress blog for communications:
[url= http://carlinapps.wordpress.com ]carlinapps.wordpress.com[/url]
Cheers,
Bård
Allthepies...or others
I went with the manual approach, but want to try FB. Ive found the Activities app in FB, and gone to Source -> Add Source. Clicked on Endomondo and put my email and password in.
It says validating for about 1 second and then does nothing..
Whats going wrong??
Ta
If using Chrome it's easy. Download the gpx and it should appear in a little box at the bottom. Open strava and the import activity tab, then simply drag and drop the download into the box.
