Effect on head angl...
[Closed] Effect on head angle of smaller rear tyre.
 Earl
Usually run 2.1 both F&R.
How much difference in head angle/handling would running a 2.3F and 2.1R make? Noticeable or negotiable? What would be the equivalent reduction in travel if I were to correct it with a u-turn fork?
Posted : 25/12/2010 11:59 pm
you could turn your fork down by .2"
difference in head angle will be less than a quarter of a degree otherwise.
Posted : 26/12/2010 12:15 am
Going for a carp before getting on the bike would probably have more of an affect.
Posted : 26/12/2010 12:22 am
Al knows. He's a maths boffin.
Assuming each tyre has got a 100% aspect ratio, that's 0.2" on the diameter, or 0.1" on the radius.
That's less than the tread depth.
Do you notice a change in the head angle as your tyres wear down ?
Posted : 26/12/2010 12:44 am
radius, not diameter.
and given his tyres year equally how would that change the geometry?
ooh...bottom bracket height! ๐Ÿ˜€
Posted : 26/12/2010 9:26 am
Aha, but what happens as his camel back drains?
Posted : 26/12/2010 10:00 am
But rear tyres wear a lot quicker than fronts.
Cause we all secretly love a nice skid every now and again. ๐Ÿ˜†
Posted : 26/12/2010 10:07 am
and when he goes for a pi$$ ๐Ÿ™‚
Posted : 26/12/2010 10:11 am
stu you have not accounted for the higher pressure in his rear tyre ๐Ÿ˜Ž
Posted : 26/12/2010 10:12 am
๐Ÿ˜†
Posted : 26/12/2010 10:13 am
I said radius. ๐Ÿ˜•
Anyway, there seems to be more than 0.1" radial run out on the average mountain bike tyre from what I've seen.
That means the frame geometry must be changing with every revolution of the wheels.
In fact, the change would constantly vary during a ride depending on whether the high and low spots on the two wheels were synchronised or not.
It's a wonder anyone ever manages to ride a bike.
Posted : 26/12/2010 10:20 am
