Edinburgh Cyclist a...
[Closed] Edinburgh Cyclist and Jaguar
 sbob
Well is he in front of the Jag or behind it?
These are not the only options, and you know that.
A poor start to your argument and one that marks you out.
Behind which red car?
You see this is really telling.
I clearly wrote "when he emerged from the minor road, either behind the red car or possibly between the blue and red car".
See the red car at 5 seconds as the cyclist approaches the give way lines?
I'm guessing using the term "give way lines" is probably causing you greater confusion. ❓
The incident happened half a mile up the road from where you're suggesting he put himself in the wrong road position
Incorrect.
That's where the incident ended, when the cyclist fell off, but it started when he pulled out of the minor road with insufficient plan.
The only connection is the driver with rage
I think you'll find the cyclist was also there.
who decided the cyclist is in his way because he's in front.
What is in front of the stationary Jaguar?
It's a car.
What is the distance between the two cars?
Clue: it's insufficient for a bike.
The bike is not in front.
The bike may be fractionally ahead, to the left, but he is not in front.
That is why the cyclist has to cut up the Jag, and that is why the Jag driver was angered.
If that was a car driver indicating to force his way in front of a cyclist, would you be defending the driver?
If you had a conflict with a motorist at a junction like that (although I personally think there is plenty of tarmac for both to make the corner) would you then position yourself in front of that motorist?
Very foolish.
Posted : 09/12/2014 4:33 pm
 sbob
imnotverygood - Member
Doesn't make any difference to the risk posed by the junction.
It wasn't the junction that caused the cyclist a problem.
It was his impatience that caused him to cut up the Jag driver.
My advice would not have led to him cutting up anyone.
Posted : 09/12/2014 4:38 pm
[quote=imnotverygood ]Assuming he doesn't live down that road? Sorry. I didn't realize he was a friend of yours. Just covering all the bases 🙂 I had a look on Google Maps to see if there was somewhere significant down there (offices or something) but there didn't seem to be.
Posted : 09/12/2014 4:39 pm
You need to read my other posts. Sitting in the traffic at that junction won't stop cars cutting you up/taking you out. The fault lies in the way the junction is laid out. An ASL might be useful so you can get round the corner before someone takes out their impatience on you.
Posted : 09/12/2014 4:41 pm
Bike rider was a knob.
Jag driver was (probably) a knob.
People referring to drivers using their vehicles as weapons......well, they should probably know better. 🙂
Posted : 09/12/2014 4:43 pm
 sbob
You need to read my other posts. Sitting in the traffic won't stop cars cutting you up.
What are you talking about?
It was the cyclist who cut up the driver in the video that we are discussing, not the other way around.
Posted : 09/12/2014 4:46 pm
Well, I'm talking about being someone who has had a good look at the junction in [i]real life[/i]. So what I'm saying is that sitting in the line of traffic and acting like a car is not a particularly safe way of trying to get through the junction. What you ascribe as the cyclit's impatience is in fact him trying to find a safe way to use a tricky piece of road layout. That's what I'm talking about.
Posted : 09/12/2014 4:51 pm
I dont see any contact there. Appears to me the cyclist was far to busy getting involved to keep his eyes on the road.
IMO cyclist was in the wrong to start with, jag driver overreacts
Both clearly dicks
Posted : 09/12/2014 4:57 pm
[quote=sbob ]You see this is really telling.
You did, but when he comes out of the junction there is no red car in front of him to pull in behind. I can only assume you mean the correct thing for him to do is to turn right and pull in behind the red car, which is clearly completely nonsensical, and illustrative of the quality of the rest of your argument. Can I just check whether you think he should actually turn right and then do a U turn, or should he squeeze by on the car's left hand side on the wrong side of the road?
Incorrect.
Where the cyclist was knocked off (I note the car defenders seem to want to give a different impression). That was where the incident started and ended. As I've thrashed out with James, the cyclist had clearly forgotten about the earlier stuff by then, it was simply the driver who wanted to pick it up - no direct connection at all between the two.
The cyclist at the point the incident happens, and then a bus.
Posted : 09/12/2014 4:59 pm
 sbob
Well, I'm talking about being someone who has had a good look at the junction in real life. So what I'm saying is that sitting in the line of traffic and acting like a car is not a particularly safe way of trying to get through the junction
That's your opinion, fair enough if that's the way you feel.
Bollocks.
The first thing the cyclist does is pull out of a junction where there isn't space to establish himself.
Safety is obviously not his priority.
Which is my opinion.
Which is backed up by the cyclist then choosing to position himself directly in front of the driver he has knowingly pissed off.
Posted : 09/12/2014 5:01 pm
[quote=tpbiker ]I dont see any contact there.
Well I guess the camera isn't actually pointing towards the car at that point 🙄
Have seen a few people make this comment - do you really think the cyclist is making up the collision?
aracer - Member
No he didn't. He pulled back into the queue behind the bus. I'm sure if there had been another car in front of the Jag he'd have pulled in front of that - I don't think he even thought about the car when he pulled into the queue there, so didn't realise there was likely to be an issue.
But I don't think those who think the cyclist was just out to cause trouble will ever be able to see that.
The driver should absolutely be reported.
Pure chance that the Jag was behind the bus (not that that justifies the Jag's actions, see sentence above.)
Am I alone in not filtering up EVERY SINGLE QUEUE I find?
As for the saying cyclist is not looking for trouble, why does he turn to look at every licence plate in the first queue?
Live and let live on the roads I say, some cyclists are too far ahead if the curve (the curve of "we must overtake all cars" - something I find myself criticising drivers for against us cyclists).
Posted : 09/12/2014 5:02 pm
[quote=aracer ]the cyclist had clearly forgotten about the earlier stuff by then
You know what the cyclist remembered just by watching that video? Can you tell us what he had for breakfast too?
Posted : 09/12/2014 5:03 pm
Why is there the need to pull in front of the car anyhow to begin with? the road is well wide enough for a car and a bike. Cyclist is trying to take control of the lane when there is no need. If he gets infront of the first car, he's off and across the junction before the first car has barely moved. Piss poor road awareness from the cyclist.
Cyclist is being a bit of a bawbag if you ask me and antagonising the driver. Fact he looks at every driver on the way up and comments on the one he picks on, suggests the antagonisation was premeditated.
I'd be wary of reporting that to the polis, you'll get yourself in bother.
Posted : 09/12/2014 5:06 pm
I don't like the cyclists position at the lights ( I would have gone to the front left made eye contact with the guy in the front car and indicated my intention to go right ) but all he does at that point is do the same but to the jag driver a safe thing to do to ensure he does not get creamed if the jag plans to go straight on . Later on he is not being a cock by positioning himself centrally absent a cock in the car behind that is the best safest place to be . The jag repeatedly tries to force past to get nowhere . At which point I'd have been tempted to lose him by going down the centre. But at no point is the cyclist wrong to try and keep his lane position .
Posted : 09/12/2014 5:13 pm
 sbob
aracer - Member
This is priceless.
At no point, despite me using the term "give way" do you even for one moment consider that the cyclist should, or even could have given way to the traffic already established on the road he intends to enter.
That tells me everything I need to know about your attitude to safe road use.
Your continued attempts to ask me to choose from options 1 and 2, when 3 to 6 are also available, even when I have already pulled you up on this juvenile tactic also tells me everything I need to know about your ability to discuss something in a sensible and adult manner.
You are completely and obviously wrong.
So now you know what the cyclist was thinking?
Can I borrow your crystal ball for the lottery?
Merry Christmas.
I hope Santa gets you a really good quality bicycle helmet.
Posted : 09/12/2014 5:14 pm
both are being dafties, but do you think the jaguar driver would have bumped into the cyclist had the cyclist been driving a car rather than on a bike?
and what have bike helmets got to do with it?
Posted : 09/12/2014 5:18 pm
Which of course you are entitled to. It is just that having actually seen the junction I think you are wrong.
FWIW I have been pondering on the chevrons (as you do). I get the sneaking feeling that they pre-date the traffic island and were originally put there to prevent a free-for-all with cars going straight on and right when the island wasn't there. Doesn't mean that legally you can ignore them, but there are more heinous crimes than failing to obey obsolete road-markings which probably should have been removed. There: You can all go to bed without worrying about them now.
Posted : 09/12/2014 5:19 pm
I find myself mostly agreeing with [b]aracer[/b] on this one and like him I find it disturbing how many people on a cycling forum appear to support the idea that cyclists shouldn't be on the road or should stay in the gutter.
That said, I also agree with [b]sbob[/b] that the cyclist made the initial mistake - though it was the Jag driver that then escalated it.
Here is the streetview of the junction for anyone that is interested:
https://goo.gl/maps/C0HqF
As others suggested, staying on the left of traffic wasn't an option there as the traffic can go straight on or right and the cyclist wants to go right.
The cyclist's mistake (as I see it) was filtering up the left when he knew he wanted to go right at the lights. He [i]should[/i] have joined that queue properly, adopting a primary position behind the blue car at the start of the clip.
[i][b]BUT...[/b][/i] the jag driver clearly knew he was there and clearly knew he wanted to turn right, but instead of doing the decent thing (i.e. being forgiving of someone being a numpty and letting him in) he decides to teach him a lesson instead by sounding his horn and trying to use his car to block him as they turn.
Not cool.
Having identified the Jag driver as potential aggro the sensible thing to do would have been to just stay in the queue of traffic behind the bus. Filtering in front of the jag was a legitimate legal move, but not a very sensible one.
And of course the Jag driver ramming him and leaving the scene was completely unacceptable, regardless of what occurred before that!
Posted : 09/12/2014 5:20 pm
himupstairs - Member
I think it's debatable whether there's any contact going on there.
Posted : 09/12/2014 5:22 pm
If he gets in front of the first car he can go what ever way he likes and will be much faster off the mark than the cars.
It's stupid to filter all the way up and sit behind the first car.
Posted : 09/12/2014 5:23 pm
I think he was thinking "yes, finally got one, can't wait to get this on youtube later"
Posted : 09/12/2014 5:28 pm
 sbob
Graham's somethingion is good.
Cyclist shouldn't have pushed in front of Jag.
Jag should have hung back to allow for the cyclist's error.
He didn't.
Cyclist would have been clever to have then kept the Jag in front of him, the only position in which he has any control over their interaction.
As is often the case, it takes two pricks to have a sausage meat sword fight.
Posted : 09/12/2014 5:30 pm
ok, so if he didn't bump into him, do you think the jaguar driver would have tried to aggressively bully his way past the cyclist the way he did if the cyclist had been driving a car and not riding a bike?
 sbob
Having stolen aracer's crystal ball, I have a feeling with his attitude that he will probably end up needing one. 😉
Posted : 09/12/2014 5:32 pm
presumably you mean for mounting a gopro to?
Posted : 09/12/2014 5:33 pm
 sbob
Yes, that's exactly what I mean.
Merry Christmas.
Posted : 09/12/2014 5:35 pm
cool, just checking.
wouldn't want to be starting a helmet debate on here after all..!
Posted : 09/12/2014 5:36 pm
 sbob
If the cyclist had been driving a car, he would never had bullied his way in front of the Jag in the first place. 💡
why's that?
Posted : 09/12/2014 5:37 pm
If the cyclist had been driving a car, there wouldn't be any potential issues with people trying squeeze past to beat the traffic lights, or for people trying to overtake him as he turns right.
Posted : 09/12/2014 5:39 pm
 sbob
Are you sure?
sbob is pro helmet, pro choice, and chooses not to wear one.
I don't need one as I don't own a go-pro, and subsequently don't get knocked off my bike.
Posted : 09/12/2014 5:40 pm
Ahh right, because all drivers are patient and polite? of course!
Posted : 09/12/2014 5:42 pm
If the cyclist had been driving a car he'd have joined the queue of traffic behind the blue car at the very first junction and been nowhere near the Jaguar.
Posted : 09/12/2014 5:45 pm
I don't know if it's relative to the discussion, but I'd like to take this opportunity to raise awareness of the humiliating psychological effects of erectile dysfunction...
sbob, i share your views re helmets. nae quibbles there.
i do find the gopro thing funny - especially as the cyclist in the vid is clearly hoping to catch someone fiddling with their phone whilst sitting in traffic.
then gets a little more than he hoped for!
Posted : 09/12/2014 5:46 pm
[quote=sbob ]At no point, despite me using the term "give way" do you even for one moment consider that the cyclist should, or even could have given way to the traffic already established on the road he intends to enter.
Er, no. I considered that he quite clearly had given way. Because he hadn't done anything "likely to endanger the driver of or any passenger in a vehicle on the major road or to cause the driver of such a vehicle to change its speed or course in order to avoid an accident" http://www.legislation.gov.uk/uksi/2002/3113/regulation/25/made Of course if anything had been moving on the road, or there hadn't been plenty of space to move into, then clearly that might have been an issue, but it wasn't and there was.
Hence I was ignoring your reference to that.
Why, what did you think "give way" meant? How do you think you "give way" to stationary traffic?
Posted : 09/12/2014 5:50 pm
raise awareness
 sbob
yunki - Member
I drive a twenty year old Nissan Micra with flower stickers on it. That pretty much guarantees my status as a sexual tyrannosaurus.
And it's an auto.
I can feel your wives trembling from here.
Posted : 09/12/2014 5:54 pm
[quote=sbob ]Can I borrow your crystal ball for the lottery?
Can I borrow yours?
[quote=sbob ]Which is backed up by the cyclist then choosing to position himself directly in front of the driver he has knowingly pissed off.
Because it seems far more likely to me that the cyclist is simply ignoring the car and it just happens that the convenient space is in front of it, than deliberately putting himself in front of it to piss the driver off. Give me one piece of evidence to suggest otherwise...
Posted : 09/12/2014 5:59 pm
I can feel your [s]wives[/s]thighs trembling from here.
FTFY 😉
 sbob
You were ignoring my reference to it because it doesn't suit your selfish style of road use.
Except there wasn't plenty of space to move into, he had to force his way in front of the Jag.
How do you think you give way to stationary traffic?
Are you saying you would have pulled out if you were in a car?
Does traffic cease to occupy space at zero velocity?
That's mental.
Posted : 09/12/2014 6:02 pm
Posted : 09/12/2014 6:03 pm
[quote=sbob ]You were ignoring my reference to it because it doesn't suit your selfish style of road use.
Actually on second thoughts I don't want to borrow your crystal ball. I was ignoring it because it clearly didn't apply - are you disputing the law I've given you a link to?
er, 'At no point, despite me using the term "give way" do you even for one moment consider that the cyclist should, or even could have given way to the traffic already established on the road he intends to enter.', 'See the red car at 5 seconds as the cyclist approaches the give way lines?' - we were talking about giving way at the give way lines weren't we? Or is there some other point you wanted him to pull behind the red car?
That's mental.
Well quite clearly not, because there wouldn't have been space to pull into. With a bike there is. The other traffic is irrelevant because there is still plenty of space even with it there. If you think he didn't obey the "give way", maybe you could give a link to the law you think he's broken if you don't like the law I found regarding give way lines.
Posted : 09/12/2014 6:09 pm
Page 3 / 5
