Ebikers - how many ...
[Closed] Ebikers - how many chains to a cassette?
And how often do you rotate them ? I have a Vitus E-Sommet on order which has an SLX cassette and a KMC X11E ebike specific chain. So not an expensive cassette but I'd still like to get max value given how ebikes are supposed to wear drivetrains - two chains or three?
Posted : 14/04/2018 8:22 pm
One. Change it when it needs it. And on that day the bike gets something shiny and new.
Posted : 14/04/2018 9:49 pm
Is that ebike specific advice Nick?
Posted : 14/04/2018 9:59 pm
I'm still on original chain, cassette and front sprocket (bosch motor scott e-genius), done 4500+ miles and the rear sprocket looks like a throwing star so i guess i'd better renew the drivetrain before i head up to Aviemore next month
Posted : 14/04/2018 10:05 pm
I've got a specialized Levo. I think the problem with people burning through chains is the fact you strain the chain a lot more by using a harder gear when climbing. Use the gears like a non electric mtb and the chain should last just as long as a normal bike.
I could be wrong. I am not a trained ebike tester, but it does seem easy to rely on the motor and launch yourself up a climb in a gear you would never use on a normal bike.
Hmmm, interesting. Thanks both
Posted : 14/04/2018 10:10 pm
Just buy a chain checker & replace chain on 0.5 wear rather than 0.75
Posted : 15/04/2018 12:23 am
Currently up to 521 miles on an E-sommet - using Squirt every ride and up to 20%wear on a Park Tool chain tool in soft muddy conditions.
Dark Peak grit would be a different matter.
Definetly a case of putting a bit of effort into maintaining an ebike drivetrain.
E-sommet is an absolutely stunning bike!!!!!
Posted : 15/04/2018 12:31 am
Not a bad shout RD, ta.
Thanks mundies. Have used squirt for a few years and really liked it but on Smooth now which is even better, give it a go.
Anyway, give us a mini e-sommet review while I'm waiting for mine then!
Posted : 15/04/2018 1:11 am
On Mrs M’s Bosch powered unit I find the front sprocket requires changing when the chain is worn rather than the cassette.
Posted : 15/04/2018 11:03 am
