Easy tubeless of 80mm Holy Rolling Darryls with On-One floaters:
1. Seat tyre with a normal inner tube
2. Remove tube through one side- leaving one edge seated
3. Get 20" Down hill Schwalbe innertube (not a typo- 20" size makes it nice and snug
4. Cut along top seam to open out the inner tube
5. Stretch onto rim- it should go edge to edge
6. Inflate tyre - you'll probably need a strap to hold it down and push the bead out, and a compressor
7. Remove valve core and chuck in some sealant
8. replace valve core and pump up a few times.
9. Ride!
It worked really easily for me. The inner tube is the perfect fit for 80mm rims. No tape or bulking required. Didn't swear once. Tube's here or from your LBS ( http://www.merlincycles.com/schwalbe-sv7-av7-inner-tube-20-โฆ)
Posted : 09/03/2015 1:33 pm
