Eastridge or Hopton...
[Closed] Eastridge or Hopton Wood choices
I'm bunking off work on Friday.
Both Hopton and Eastridge woods are a similar distance from my house.
Which one has the better XC route ?
Posted : 06/09/2017 1:02 pm
If say hopton has the better xc route East ridge has alot of good trails but probably more 'enduro' .
Posted : 06/09/2017 1:18 pm
^^ What he said
Posted : 06/09/2017 1:21 pm
Is the Hopton route marked clearly as I don't have a GPS?
Posted : 06/09/2017 1:36 pm
Yes ๐Ÿ™‚
Posted : 06/09/2017 1:37 pm
^^ what they said, however an Eastridge and stiperstones xc ride is better if you're not after a just follow the signs ride.
@mrhoopy around about how long is that route?
Posted : 06/09/2017 1:44 pm
Hopton is a great little route it is marked but there is a section where you will end up on the downhill route if not paying attention ,you get spewed out into a field and it's a steep walk to get back up , thought it was just me but as I'm getting my bearings in the field another couple of lads arrive with great big grins but a look of bewilderment about them having done the same thing . If you see road sign chevrons on the trees then your on the wrong route
Posted : 06/09/2017 1:45 pm
About 24km, or thereabouts, it's a decent half day ride.
Posted : 06/09/2017 2:56 pm
Hopton is great.
When you ride through the quarry at the bottom then climb on the fireroad. A few minutes after you re-enter the singletrack on a climbing sharp left hander, look on the right for a little trail that drops back into the trees. It leads back down to the quarry and is a nice little extra. ๐Ÿ™‚
Posted : 06/09/2017 4:06 pm
The off piste on either is excellent, steep and tech without being too stupid!
Posted : 06/09/2017 4:09 pm
I'm off there this friday. I'm planning on doing Eastridge then move on to Hopton afterwards. All before riding on Long Lynd itself on Saturday. Is this plan ok, or should I map out an Eastridge/Stipperstones routes instead for the Friday?
Posted : 20/09/2017 12:57 pm
Just so I plot the best route, which are the best descents and kindest climbs at Stipperstones?
Posted : 20/09/2017 1:08 pm
