Easton Road Hub - F...
[Closed] Easton Road Hub - Freehub Service Suggestions
The hub froze up the other day (no drive), so I assumed it would be
1. Skewers out
2. Allen keys in either side
3. Disassemble, clean & dry, light oil/ptfe spray
4. Reassemble
BUT allen keys don't fit, the skewers sit in a smooth bore.
Any suggestions? ultimately LBS will sort, but I don't want to get caught out on the trail again, so need to know.
Posted : 19/02/2012 2:23 pm
I'm sure the hub type would be beneficial for an accurate answer but in the meantime you might want to have a quick gander at [url= http://www.eastoncycling.com/en-us/road/technology/downloads/wheel-service/ ]Easton's[/url] downloadable PDF page...
Posted : 19/02/2012 3:20 pm
If there is no obvious way that the end caps are secured then generally they will just pull off and the freehub should do the same.
Posted : 19/02/2012 5:25 pm
You guys are right on the money again. The Easton manual showed the job perfectly (when I found the right one). Devilishly tricky and not a trailside repair.
If all only all hubs were made by Hope.
Nice one. Many thanks.
Posted : 19/02/2012 11:39 pm
