Easiest way to conn...
[Closed] Easiest way to connect an iPod to a car with no aux input?
Got an accord with the sat nav and unfortunately as its a late model the technology is quite old so it has no aux in.
I can get a box of tricks that plugs into the cd multi changer and kids it but it involves stripping the dash and its about £120
Is there something like the parrot that will work, be cheaper and easier to install? I'm not sure how these work exactly
Posted : 21/06/2013 9:57 pm
I use a jabra cruiser over BT that streams to an FM frequency.
Posted : 21/06/2013 9:59 pm
As above, however I found they sucked battery so make sure you have a charger.
Posted : 21/06/2013 10:03 pm
Have a look at connects2 - I picked up something g for a out £25 that plugged into the back of the stereo.
Posted : 21/06/2013 10:04 pm
2nd the Itrip. Works great (until you travel a bit & a radio station crops up, then you need to re-tune, easy peasy)
Posted : 21/06/2013 10:06 pm
I always thought my Griffin itrip charged the ipod as well through the cigarette lighter, but don't quote me on it.
Edit - Just checked, the Griffin itrip does charge your ipod as well.
Posted : 21/06/2013 10:10 pm
Fit an aux input.
That's what I did to our Focus. Cost £25 for the genuine Ford kit. Unscrew glovebox, drill hole for socket, plug wire into back of radio.
Job done.
