DVO Jade X Spring
DVO Jade X Spring
Im after some help please, im trying to source a 600 x 3 inch (or 2.5 with a spacer) spring for the DVO Jade X shock. Im not sure on compatible springs and i cant find the DVO LS spring in the correct spec anywhere. Suggestions welcome. TIA
Posted : 17/05/2023 12:22 pm
Nuke Proof, Cane Creek, Ohlins and Fox should all be compatible with DVO shocks. Rock Shox are a different internal diameter, though.
I have used Cane Creek VALT and an NP Ti spring on a normal Jade with no issues, and the VALT also fits an Ohlins TTX22m with no issues, so would assume an Ohlins coil would fit the Jade X
Posted : 17/05/2023 1:29 pm
Cane Creek springs fit.
Speak to Windwave UK as they are DVO's UK importer
You can buy direct from them too
Posted : 17/05/2023 10:56 pm
I went for the Nukeproof spring. It arrived this morning from CRC and ive fitted it. Night and day difference ๐Ÿ™‚
Posted : 18/05/2023 12:51 pm
Hi all,
I'm just about to pull the trigger on an Ibis Ripmo AF. It comes with a 500lbs spring which is too much for me. I'm about 170-175lbs depending on gear. I've not owned a coil before and I'm really confused as to what spring size should buy. I think I need a 450lbs spring, but I'm unsure what size. The shock shows as 210x55. Coils look to be 2.5" or 3". Is this a 2.5", and will any Nuke Proof, Cane Creek, Ohlins and Fox coils fit?
Sorry for the load of questions, as I say, I'm new to coils!
ย
TIAย
Posted : 11/04/2025 7:49 pm
Hi all,
ย
ย
ย
ย
ย
ย
TIAย
Posted : 11/04/2025 7:50 pm
You may be ok with the 500. My Ripmo AF has this fitted and I'm 85kg without riding gear. I find I can achieve the correct sag (15-18mm) with barely any preload wound on, I'm actually thinking of getting a heavier spring.
Posted : 12/04/2025 10:14 pm
