Dumb-ass brake moun...
[Closed] Dumb-ass brake mount question.....
3 Users
Here's the thing..... i have a post mount rear on my frame and run 160mm rotors, if i were to buy a rear brake calliper for IS could i adapt it to run on my post mount/160mm rotor set up?
if 'yes' could you direct me to the adaptor i'd require please?
thanks in advance
Posted : 08/07/2012 11:05 am
I don't think it's possible to keep the same rotor size. You'll probably have to go up 20mm, though Hope used to do a +10mm adapter.
Posted : 08/07/2012 11:32 am
Do you mean a Shimano Mount Adaptor Rear Post to IS 160mm
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=13749 ]Rear Post to IS 160[/url]
Posted : 08/07/2012 12:23 pm
captainscrumpy - Member
Rear Post to IS 160
that looks like it'll do the job.......thanks capt'in 😀
Posted : 08/07/2012 1:14 pm
I may have misunderstood you, I thought you had post mounts on your frame.
However, that adapter is [b]"to mount a 74mm post mount caliper to a 51mm international standard frame mount to accomodate a 160mm disc"[/b], it won't let you mount an IS caliper to anything.
Posted : 08/07/2012 1:21 pm
Johnners - you're right, you didn't misunderstand.....the search continues 🙁
Posted : 08/07/2012 4:48 pm
