Dual crown enduro -...
[Closed] Dual crown enduro - the future or OTT and marketing
Zero stack anglesets on their way as well.
Posted : 12/07/2021 11:28 am
Yetis have been known to shear headtubes clean off with just regular forks
In which case they get filed under shite bikes no right thinking person should buy.
Posted : 12/07/2021 11:31 am
I’m sure there would be some benefits for Fox and RS too
of course because "mtb", RS actually had the perfect fork years ago in the Boxxer Ride U-turn. The U-turn wouldn't be needed, but it was just a slightly lower travel Boxxer Team otherwise
Posted : 12/07/2021 11:33 am
 StuE
Knock block on some Trek bikes limits how far you can turn the bars possibly more than dc forks and it doesn't seem to have been an issue
Posted : 12/07/2021 12:58 pm
 5lab
the speccy enduro evo expert came with a (stock) 180mm boxxer a few years ago. Looked mint too..
Posted : 12/07/2021 2:10 pm
Dual crown forks make so much sense on bikes like that. I for one welcome our new triple clamped overlords.
Posted : 12/07/2021 3:15 pm
The weight of a dual crown would make for slow inclines.
I used to ride 5" & 7" Jnr Ts, and Shiver DCs. But only on bikes/rides where I would pedal a few times then drop off something, or point downhill and bounce around like in a pinball machine. I'd normally be walking up any hill I needed to get up.
Posted : 12/07/2021 6:26 pm
I welcome it. I'll just need to get out more. No more squeezing CSUs.
Posted : 12/07/2021 6:30 pm
Why?
Do you realise that the Shiver DC came out 20 years ago?
If I had to guess at the kind of bike you were riding back then I'd suggest it probably wasn't just the fork which made it unpleasant for climbing.
Posted : 12/07/2021 8:12 pm
you do realise the Formulas that kicked off this thread are lighter the the RS/Fox single crown equivalents?
Posted : 12/07/2021 8:45 pm
Plus, Shivers were heavy even for their time. My Super T's are about 3kg but that's fully coil sprung and HSCV in both legs. As I said earlier in the thread, one leg is essentially redundant so you could modernise it just by moving spring and control to seperate legs and save a load of weight that way. The 7" frame it's on also weighs more than my "new" DH bike.
Posted : 12/07/2021 10:18 pm
That would require actually reading instead of an immediate knee-jerk reaction!
I'm sure when 29ers were first introduced people were harping on about it being all OTT and marketing balls, same with rear suspension, disc brakes etc. It's always the case.
Since I live quite close to Geometron HQ and they're the Formula distributors in the UK, I am absolutely going to see if I can demo their enduro dual crown once it's out.
Posted : 14/07/2021 9:27 am
I seem to remember having a dual-crown and light fork in 2007… Specialized e150SL anyone! Post-tuning, they were a well-damped, predictable fork that resisted twist. Seems like we are going back full-circle, somewhat.
Posted : 14/07/2021 1:20 pm
mrdestructo
Nah. We're talking pretty small amounts here, no different from say going from a 34 to a 36, or fitting a coil, you don't suddenly go oooooh this climb is so slow.
mashr
Is it? It's been described as "lighter than some single crown fork", but are they equivalents?
mashr
RS actually had the perfect fork years ago in the Boxxer Ride U-turn. The U-turn wouldn’t be needed, but it was just a slightly lower travel Boxxer Team otherwise
It was, let's be honest, a bit shit. The first lyrik came along what, 2 years later and was a ridiculously better fork
Posted : 14/07/2021 2:42 pm
Not possible, due to the stanchions, silly.
Posted : 14/07/2021 2:44 pm
Is it? It’s been described as “lighter than some single crown fork”, but are they equivalents?
Its lighter than the 38mm forks from RS and Fox. Whether you consider it equivalent is of course up to you but it offers the same travel, and probably better stiffness.
Posted : 14/07/2021 3:02 pm
Northwind
It was, let’s be honest, a bit shit. The first lyrik came along what, 2 years later and was a ridiculously better fork
I think your Lyrik-tinted sunnies are getting in the way. It was a (MoCo, including Floodgate) Boxxer Team with 22mm less travel, it was great. I had the Team and the other half had the Ride. I've seen reports of the U-turns self adjusting, but as ours never did it I can't really comment. Not sure why you think the, also MoCo, Lyrik was better?
OTOH if you're thinking of the original/older version of the Ride, then you are onto something
Posted : 14/07/2021 3:51 pm
mashr
Nah, I had the Ride (and a late model 32 Team in my 224), it was an ancient chassis with a basic damper in, even with the revised rebound the moco wasn't really up to the job. The lyrik with mission control was like a fork from the future in comparison. (and of course was a very close relative of the first 35mm Boxxer).
Put it another way, that first lyrik still stands up as a good fork today. The chassis is super heavy but the damper was superb. The disappontment when I "upgraded" to a 35mm charger Pike was huge, so I went back to the Lyriks and kept them right up until I went 29er. And I'm still using a set of mission control Boxxers so there's no rose tinted glasses there.
Course, the 2-step air exploded instantly on literally every lyrik but you can't have everything.
Posted : 14/07/2021 4:07 pm
Page 2 / 2
