Been servicing my 2008 reba SL and got the air spring apart to find the travel spacer broken..but it was running at 115mm so I wasn't expecting to find a spacer in there!
[url= http://imgur.com/r7BbE6Y ]Link to photo[/url]
I got the forks second hand quite a while ago and looking at the manual (see link) with the bits I've taken out on top of it, I think I'm missing a bit! It looks like there should be a spacer where the left hand diagram says "no spacer".. No sign of it. Can I run the fork without it? Looks like whoever had the fork before put the travel spacer in this space.
Hmmmm
Any thoughts appreciated!
Adam
edit- step 7 on [url= http://faqload.com/faqs/bicycle-components/suspension/rockshox-sid-race-2009-2010-adding-removing-all-travel-spacer ]here[/url] seems to suggest I don't need it..? Are 2009 SID's much different?
Right I'm getting confused here...! Have there been a few different versions of the dual air spring..? Mine looks like the one from the SID (link in previous post) but the one in the manual looks [url=
]like this one[/url]! From the 2009 manual I think the bit I'm missing is called a negative air piston, which sounds like more than a spacer! Can I buy it seperately?
Cheers,
Adam
