DT Swiss XM 1501 ri...
[Closed] DT Swiss XM 1501 rim replacement
[#11483122]
Think I might swap the rear rim on my wheels, which are DT XM 1501 35mm inner width, Im guessing they are XM 521 rims (?)
What is the next strongest 30-35 internal DT rim that will swap straight over- EX 511 ?
Posted : 16/11/2020 5:41 pm
Correct on both fronts.
Posted : 16/11/2020 5:49 pm
 mboy
Yes, XM1501 wheels use the XM series rims, in your case the 35mm wide run the XM521 rims.
Replacing with an EX511 isn't a bad idea, as long as you don't need the extra rim width. It'll be quite a bit stronger, and more use for "normal" width tyres (that is to say 2.3-2.5 rather than 2.6-2.8 that a 35mm rim is better for).
Posted : 16/11/2020 5:50 pm
Yes I use 2.5 tyres generally, thanks will have a looky for some 511s, think they are in stock at CRC.
Posted : 16/11/2020 5:53 pm
If you do want the extra width and to go up a notch strengthwise the HX 581 E-MTB rim is 35 mm wide and a very sturdy beast indeed.
Posted : 16/11/2020 6:10 pm
