DT Swiss RWS Thru B...
[Closed] DT Swiss RWS Thru Bolt anyone used one?
[#2169529]
seems a bit pricey, but anyone had any experience if it stiffens up a qr rear end?
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=21670 ]clicky[/url]
Posted : 08/11/2010 6:20 pm
They work but the resin ratchet lever is fragile and the splines strip off them alarmingly easily unless you're very, very careful. And they're ridiculously expensive.
I reckon you're better off either getting a simple 10mm bolt or one of the [url= http://superstar.tibolts.co.uk/product_info.php?cPath=32&products_id=287 ]10mm rear QR[/url] things that Superstar sells.
And yes, it does make a detectable difference particularly on fast rocky stuff imo. Not as much as replacing a front QR though.
Posted : 08/11/2010 6:34 pm
ooh, £7.99 from superstar
thats a winner a think
cheers badlywireddog!
Posted : 08/11/2010 6:37 pm
 Crag
So, do these just work with standard QR wheels?
Posted : 08/11/2010 8:00 pm
I just wondered the same thing. Short answer is yes but, long answer is well kinda.
If your standard QR wheel has a removable QR axle (ie the wider axle that the QR bolt slides into), then you take that part out and slide in the 9mm axle. If your hub has no removable QR axle (eg Hope XC) then nope, doesn't work.
Posted : 08/11/2010 8:10 pm
The SS 10mmqr can be made to fit a pro2 rear hub as there is a conversion kit available for them, or you can just get a 9mm drill and make your own like I did. I figured there was nothing to loose as t
if it went wrong it was just a case of buying the conversion axle, saved myself a whole £15 as well...
Posted : 08/11/2010 10:00 pm
double post due to crap internet connection and fat fingers...
Posted : 08/11/2010 10:01 pm
what do you need to convert a rear pro II qr to a 10mm bolt thru?
Posted : 16/11/2010 11:51 pm
one of these.
www.chainreactioncycles.com/Models.aspx?ModelID=18757
Posted : 17/11/2010 12:21 am
cheers
Posted : 17/11/2010 9:22 am
