DT Swiss rear hub b...
[Closed] DT Swiss rear hub bearing change
It's on a Trek Fuel EX9 - it has a pawl freehub (not star ratchet)
Do I need to remove the ratchet ring to get the drive side bearing out? doesn't seem to want to shift with the ring in place. If so, presumably there is a special tool?
thanks
Posted : 12/06/2021 2:20 pm
DT Swiss tool to removal the 3 pawl ratchet ring is
HXTXXX00N5266S
About £60, I think you can get copies on ebay.
Posted : 12/06/2021 3:57 pm
I've done E1700 and E1900 bearing changes (both pawl) without any special tools
Posted : 12/06/2021 5:01 pm
As above 370 3 pawl hub zero special tools.
Couple of sockets, few blocks of wood, rubber mallet and a small vice. Punch for getting out the bearings.
Posted : 12/06/2021 5:22 pm
No need to remove the ring
Hear hub with boiling water
Freeze bearings
Press bearing in
Posted : 13/06/2021 10:16 am
Tried doing that to my Roval rear wheel today which I think has DT Swiss 360 internals and I can't see how you'd do it without the tool. I've just ordered one from ebay for £18 so we'll see how it goes when it arrives.
Posted : 13/06/2021 6:21 pm
Do you have a press or a drift? Press makes it super easy
Posted : 13/06/2021 6:26 pm
