Does any body know if you can get a 12 mm through axle for a Dt Swiss 240s hub ?
They only fit the 350/370 hub I’m looking for some for a 240 hub
I think you need these HWGXXX00S7564S
According to Universal Cycles: "Compatible with 2015+ black 180 front hubs (QR or 15mm). Does not fit white 180 hubs. Also fits: XMC1200, Spline 1501, RR21 DiCut and RC Carbon wheels"
The cap O.D. is 27mm, not 30mm like with HWGXXX00S7000S.
Thanks I will have a look at that
Front or rear. If front the version that takes up to 15mm or the 20mm version?
If it's a very old DT240, then the axle might need replacing- they pre-date the 12mm standard so some have a smaller hole. (and because they last forever, there's still a few of these QR-only parts out there). Otherwise, as above, endcaps. You'll need to sell a kidney but other'n that, ideal
