is it possible to dismantle without all the 'proper' tools?
took the freehub off and the bearing underneath has a type of sleeve/shroud over it...?
had a look at the tech site but it shows you all the fancy tools i should use, anyone got any bodges they use.?
The sleeve pulls off, but it will do you no good as the inner gear needs a special tool to unscrew it. This allows you to get at the bearings. I am in the same boat ATM.
You can do everything with sockets, a vice, some hardwood and some basic joinery 😉 Everything except the bearing under the ratchet ring that is...
The tool for that is £55 or something ridiculous tho the star ratchet itself is a fraction of that. Occured to me you could buy the star ratchet (two pieces obviously) then weld a big nut to one half to take an adjustable spanner ( or a socket but a bit of a waste )
It's the star ratchet; you need the DT tool to remove it - or take it to a bike shop with the tool. Might be worth ringing first to make sure they have it. Some folk bodge the tool by welding a star ring to a bolt or socket.
I thought that idea might work. Tried to find a big nut that might grab a few cogs, as usual nowt exact.
tried the welding bodge - didnt work for me - poor welds = shearing off
stupid design in my opinion as otherwise superb hubs - get a shop to do it for you
paul
It might be useful to read this other topic.
[url= http://www.singletrackworld.com/forum/topic/advice-on-dt-swiss-440-freeride-hub ]Advice on DT Swiss 440 Freeride Hub[/url]
Since then I actually purchesed the damn Ring Nut tool.
However for the life of me I can't get the ring nut to budge, I've been through the instructions 2 or 3 times, and it's clear I put the tool in a vice and turn the wheel anti-clockwise.
So back to the bikeshop it is! And well annoyed now because also have a pointless and expensive tool.
Does anyone know if there is a 15mm adaptor for the 440 front hub ?
I made the mistake of taking my rear wheel to the LBS to remove the star nut, cost me nearly £20 and they fitted it back together wrong so damaging my new bearing 😡
Needless to say lesson learnt so bought the cheap star ratchet and welded on a nut, welded it on the inside so no external flash etc. Perfect tool sorted for about a tenner.
All docs are on the [url= http://www.dtswiss.com/Service/PRODUCT-DOCUMENTS.aspx ]DT website[/url]
Can't see one listed on the DT site or CRC so I think you've out of luck, just drop them an e-mail direct, they've always got back to me on questions.
