Does anyone know if these hubs be changed from a 135mm x 10mm rear to 142mm x 12?
Posted : 18/05/2014 10:13 pm
Yes. Depending on the year it might need a new inner axle as older ones had a smaller diameter axle so you cannot fit a 12mm axle through it.
Posted : 18/05/2014 10:19 pm
Yup, deffo can as I changed mine from 142 X 12 to 135 X 9. Its a simple remove the caps and fit axle job.
Posted : 19/05/2014 3:02 pm
if you need the end caps, I have just changed from 142 x 12 to 135 x 10
if you're near leeds give me a shout and you can check if they work
Posted : 19/05/2014 4:29 pm
