Dropping the travel...
[Closed] Dropping the travel of Float 140s to 130mm
 rj
I know Fox do a spacer to drop the travel to 120, but I rather want mine at 130mm. Anyone tried to do this? I was thinking I could just machine up a shorter version of the spacer from Delrin. Or am I just being dense?
Posted : 11/06/2009 12:53 pm
Your suggestion will work fine.
Posted : 11/06/2009 12:54 pm
Why drop the travel, never got anywhere near 130 let alone 140 on my Floats
Posted : 11/06/2009 1:09 pm
Can't speak for rj but frame may be optimised for 130.
Posted : 11/06/2009 1:22 pm
Just run a tad less pressure. Get the correct dynamic geometry but with more supple suspension ... Win, win situation in management speak!
Posted : 11/06/2009 2:48 pm
 edd
The Fox drawing for a 10mm travel spacer can be found by [url= http://www.wheeladventures.com/vanilla/234-04-096_revA.pdf ]clicking here[/url]. Unfortunately the dimensions are in inches...
Posted : 11/06/2009 3:08 pm
Just use the standard spacer and cut it in half!
I wouldn't bother. I put a 20mm spacer in mine and now they sit at 135mm rather than 145mm (without sag).
Posted : 11/06/2009 4:04 pm
 rj
Nice on Edd, saves me buying one and drawing it up.
Posted : 11/06/2009 7:49 pm
 edd
No problems rj.
If you can't be bothered to get it machined then you can almost certainly get a 10mm spacer from Mojo. Give them a call on 01633 615815.
Posted : 12/06/2009 8:41 am
