Dropper post questi...
[Closed] Dropper post questions
Evening
Sadly rockshox don’t seem to list the lower tube assembly for the b1 post which means the imminent frame swap just got pricier.
ive tried tf and zyro and they confirm it.
seeing as a reverb in the correct length and diameter sits at around £200 I think it might be time to consider other options.
for the record I’ve had good reliability from my reverb, would happily keep using it.
so what 170mm drop posts around the 200 or less would people drop their money on?
Posted : 06/08/2019 10:10 pm
180mm OneUp should be less than £200 with a remote and a Brand X definitely will be.
Posted : 06/08/2019 10:13 pm
Brand X from CRC. Further £10 off with SALE2019 code brings it just below £120
Posted : 06/08/2019 10:22 pm
That brand x is cheap!
Posted : 06/08/2019 11:29 pm
Swapped out our Command posts to get the extra drop. So far been good
Posted : 06/08/2019 11:33 pm
OneUp for the most drop with the smallest stack height. Also adjustable in 10mm increments, so if you got the 180mm V2 and it was too high you can reduce it to fit. The lever is nice too.
Posted : 07/08/2019 12:08 am
