Dropper post choice
Dropper post choice
[#13535455]
So, I've just bought a new bike and it came with an X-Fusion Manic dropper which seems to be pretty decent. I also happen to have a Fox Transfer SL that fits, same drop and all that. The one thing I don't like about the X-Fusion is the fact that the cable is ran the other way round, clamps at the dropper end and nipple at the lever end.
Would you swap them?
Posted : 08/05/2026 10:01 am
no, unless weight is an issue? the SL only has up and fully down right? if weight is an issue then swap
you can always swap a different leaver on i guess?
Posted : 08/05/2026 10:20 am
You can set up the X-Fusion with any lever so it clamps the cable at both ends. Means you can use the Fox lever with the X-Fusion post if you prefer that (and want the easy set-up/adjust of the lever clamping).
Posted : 08/05/2026 10:44 am
A new bike I bought came with a fox factory transfer.  It was lovely..... when it worked.  I sent it back at least twice for a rebuild in the first couple of years.
Worked fine for a few months then got sticky. Not only that but a complete PIA to service judging by the official fox instructions.
I've had much better reliability with the cheaper brand x and ks posts so I would go with the x fusion
Posted : 08/05/2026 4:28 pm
Posted : 08/05/2026 4:29 pm
I have a Fox Transfer... it constantly gets stuck in it's lowest position, necessitating a *bum bump* to get it to return. I;ve had cheapo dropper posts which are much better.
Posted : 08/05/2026 4:41 pm
As pointed out... you can clamp at both ends with that kind of set up. My BikeYoke sort of works like that.
Posted : 08/05/2026 4:46 pm
Well, I've gone and done it, the Transfer SL is so much nicer than the X Fusion and I never had an issue with it over the previous 10 months of use.
Posted : 11/05/2026 10:56 am
