I put a big ass crack in my Bontrager Earl rim today. So thats for the bin. Decided to strip it down and keep the hub and spokes and nipples and cassette and etc. Problem is that as I deconstructed it I found out that the previous owner has at some point rounded off 2 of the nuts holding the disc to the hub. What can I do? If I drill them out then the hub is for the bin, but at least I keep the disc. Can I get them out without damaging either part?
cut a groove across the head of the bolt and use a screwdriver
try sawing a slot across the top to use a screwdriver or try gripping it with a pair of molgrips?.
Yes. Drill them slowly with 8/10mm bit until the heads fall apart, then take the disc off. If your lucky, undo what's left with a set of pliers.
Phatman - Member
I am loving the simplicity of that. What to use to cut the groove?
or drill a very small hole and use a very small screw extractor
use a mini hacksaw couple of quid from a diy store
Had to do it on two bolts today!!
Dremel is your friend!!
Hacksaw with a fine toothed bi-metal blade then?
If you can get your hand on a Dremel than that will cut a very nice groove. Use the cutter disc first of all and then use it very gently to grind out a slightly wider groove.
OK, cheers. I will begin the hunt for a dremel-weilding friend/companion/complete stranger. Wish me well!
Try tapping a slightly bigger allen key or torx head into the rounded hole first. Its worked for me a few times.
Screw extractor worked when this happened to me.
Then use torx bolts when you put it back together so you don't have to go through this nonsense again.
Tried - Failed
Sounds a most sensible idear
A friend had this problem, we clamped the head of the offending bolt tightly in a vice and then rotated the wheel. It came off fine.
Good luck.
Try aralditing a allen / torq bit to it.
*you'd think I had shares 🙂
Filing flats onto the opposite edges of the head so you can use a small spanner is more likely to work than putting a groove in for a screwdriver if the bolts are tight. Plus, if that fails, you can always try both...
