Drilling a 12H fron...
[Closed] Drilling a 12H front hub to 24H by hand, good idea?
Looking for a 24H DA 7700 front hub which ain't easy to find, but 12H hubs are more common. One seller suggested using a punch then drilling out the holes by hand. Is it that easy? I guess it doesn't need to be super accurate but it should look good.
Ideally I'd use a wise and a drill press..but only got a hand drill here https://cyclesaloon.wordpress.com/2014/12/12/drilling-extra-holes-in-front-hub/
Posted : 27/05/2022 6:31 pm
Step one would be asking yourself if youre a ham fisted bafoon. If so, then don't.
If you're somewhat mechanically able and pay attention to the small details then sure.
I assume you'll need a small chamfer on the holes so I'd see if stepped drill bits are available in the size you need..2.4-2.6mm?
Posted : 27/05/2022 6:41 pm
I've no idea how expensive old school Dura ace hubs are.
I'd wait for the 24h personally.
I've spent a lot of time drilling stuff for diy. Its never ever neat enough I'd drill a hard, curved metal hub successfully. I've not used a pillar drill for a looking time. That would make it more likely to succeed.
Can you get some time with a pillar drill?
Posted : 27/05/2022 6:59 pm
Step one would be asking yourself if youre a ham fisted bafoon. If so, then don’t.
If you’re somewhat mechanically able and pay attention to the small details then sure.
I assume you’ll need a small chamfer on the holes so I’d see if stepped drill bits are available in the size you need..2.4-2.6mm?
Hehe, depends on the day..but I have worked on handling extremely delicate and tiny structures to be scanned with electron microscopes so I can be OK.
I would need a 2.25 or 2.3 mm drill bit for the holes and 3 mm for the chamfer (measured my rear DA 7700 hub). Not sure I could find a suitable stepped bit..
I’ve no idea how expensive old school Dura ace hubs are.
I’d wait for the 24h personally.
I’ve spent a lot of time drilling stuff for diy. Its never ever neat enough I’d drill a hard, curved metal hub successfully. I’ve not used a pillar drill for a looking time. That would make it more likely to succeed.
$100 NOS. I could get a cheap pillar drill esque holder and vice for a few pounds, not sure where I'd access one here in krakow.
Posted : 27/05/2022 7:03 pm
Which hubs have only 12 holes?
Posted : 27/05/2022 7:11 pm
Dura Ace FH 7700 came in down to 12H drilling..
Posted : 27/05/2022 7:21 pm
I'd look for a centre drill with a 2.3mm tip. Then drill slightly deep and the angle of the body will give the chamfer. Also a centre drill is less likely to wander.
I'd say give it a go. I've made a few hubs from scratch and the drilling has looked ok. Easier with a drill press but should be possible by hand if you go steady
Posted : 27/05/2022 7:53 pm
I'm a ham fisted idiot and I can use a SEM.
Posted : 27/05/2022 8:11 pm
Be better done on a lathe.
Posted : 27/05/2022 8:20 pm
I’m a ham fisted idiot and I can use a SEM.
It's not using the microscope, it was the sample handling.
Posted : 27/05/2022 8:54 pm
Not really. You'd need a large 4 jaw chuck and have to index every hole manually. A rotary table with a chuck, on the mill would be best.
Posted : 27/05/2022 9:17 pm
I’m going with no, it doesn’t sound like a sensible idea.
But go for it and prove us wrong. You must promise to show us the results regardless of success or failure.
Posted : 27/05/2022 9:43 pm
I wouldn't try it without a milling machine & rotary table (and the experience to use it).
Posted : 27/05/2022 10:01 pm
Can get one of these w the vice for 28 quid..should be good enough, very high precision not req. A mill would be best, but don't have access to those anymore (I did in my TEM days, plus access to a nice CNC).
Posted : 27/05/2022 10:08 pm
I can't quote - but tbf my samples are generally quite robust.
Butterfly proboscis are the most delicate things I've "worked" with.
Posted : 27/05/2022 10:25 pm
I don't quite follow the "by hand" bit.
You're buying a pretty blingy, vintage hub then breaking out the black & decker?
If it's worth doing, it's worth doing properly find a machinist with a mill and a dividing head, or just hold on and find a 24h hub it's probably cheaper...
Posted : 27/05/2022 10:34 pm
was working on sub 1x1 mm large samples w 30 micron wide protrusion that had with nanometer thick electron transparent carbon coats on top with DNA base specifically tagged w palladium clusters on top of that again.
Usually used a dissecting microscope to handle the samples, I think most people can do fine motor work as long as they take their time.
I don’t quite follow the “by hand” bit.
Yeah but with a jig like the one above seems like an OK idea.
Posted : 27/05/2022 10:42 pm
I would do, but I have a mill and rotary table.
DIY able by hand, I would mark the PCD by scribing from the flange edge or hub centre, mark centres between existing holes, center punch and drill. Could do it by hand if you use a drill regularly, drill press would make it easier.
Posted : 27/05/2022 10:53 pm
 ctk
There are a pair of older 24h DA hubs on eBay now. Lovely hubs!
Posted : 27/05/2022 11:38 pm
 ctk
Thanks! looking for slightly newer DA hubs, got a bargain for a new 28h rear RH 7700 so looking for a front FH 7700 🙂
Posted : 27/05/2022 11:55 pm
I'd quite happily do it by hand. Me and plenty of others have made entire frames with nothing more than a hacksaw and file (plus something to stick it together with).
Using a centre drill is a very good suggestion - probably the single best bit of advice to take from this thread.
Posted : 28/05/2022 12:17 am
Yep, as along as they're within spec, just go for it, the hub's going to be boggo ali, so no drama there, I'd even hazard a guess that the hub's the same blank regardless of how many drilling it has in the end.
Hardest part will be finding the right drill size I'd have thought.
Posted : 28/05/2022 10:36 am
