DPX2 - change eye t...
[Closed] DPX2 - change eye to eye length
7 Users
Hi - I'm considering a frame change in the near future, and am currently running a 200x50 DPX2, ideally I'd like to take this with me onto the next frame but that runs a 210x52.5 - is it possible to make this kind of change in eye to eye length and stroke, or would it be too expensive to make it worth the hassle?
Posted : 08/08/2020 5:04 pm
The next frame but that runs a 210×52.5
Not a Specialized by any chance?
Posted : 08/08/2020 5:47 pm
Fox can change stroke length on OEM dpx2s, coat me about £30
But I don't think they can change eye 2eye
Posted : 08/08/2020 7:11 pm
210x52.5 is a "metric" shock, I think its a 210x55 with a 2.5mm spacer fitted to limit travel.
200x57 is one of the older, non -metric sizes. You'd need a different body/shaft I think, wouldn't be cost effective.
Posted : 08/08/2020 8:20 pm
I’m after a 200x50 dpx2 for my Hightower if you want to do a deal?
Posted : 08/08/2020 9:29 pm
Changing the eye to eye on a DPX2 is expensive. You need a lot of parts to do it and its not really viable.
Posted : 08/08/2020 10:16 pm
Assuming a 2018 DPX2 you would need a new inner shaft, outer shaft, sleeve and body, plus a full service, to go from 7.875x2 to a 210x55
Inner shaft £5
Outer shaft £18.95
Sleeve (non kashima) £74.95
body (non kashima) £31.95
2.5mm spacer?
Full service £119
Posted : 09/08/2020 1:32 pm
Thanks @bigyan
Posted : 09/08/2020 5:37 pm
