Dot 5 brake fluid f...
[Closed] Dot 5 brake fluid for my car used in hydraulic brakes??
Was about to undertake the bleeding of my brakes and was wondering if there is any difference between car dot5 brake fluid and bike dot 5 brake fluid?? Apart from the price should be the same stuff right? Please advise.
Posted : 17/02/2010 8:04 pm
same stuff. dot is dot
yup same stuff.
Posted : 17/02/2010 8:17 pm
make sure one is not dot 5 and the other dot 5.1 as they are different
Posted : 17/02/2010 8:22 pm
Its unlikley that your car will be using DOT 5.
Posted : 17/02/2010 8:31 pm
If 4 would mix with 5, will 5.1 not mix with 5?
Posted : 17/02/2010 8:36 pm
Considering the OP refered to it three times as DOT 5 it's worth correcting them.
Posted : 17/02/2010 8:39 pm
t-p 26 - Member
4 will not mix with 5 either.
Rockhopper - Member
DOT 3, DOT 4 and DOT 5.1 are similar fluids and can safely be mixed with each other.
DOT 5 is totally different and must not be mixed with anything except more DOT 5
Posted : 17/02/2010 8:53 pm
Silly Question but what bike brakes are they some use Mineral oil rather than DOT put the wrong stuff in and it will destroy the seals
Posted : 17/02/2010 10:34 pm
