Domain Travel Adjus...
[Closed] Domain Travel Adjustment
3 Users
Has anyone/does anyone know how to adjust some 180mm fixed travels domains to 160mm fixed travel?
I know that it is a relativley simple job of swapping spacers on Marzocchi forks.
Tom
Posted : 20/02/2009 2:12 pm
 will
I think it is just a case of swapping spacers, as you said, it was like that with my brother's Recons.
Best contacting you LBS for help 🙂
Posted : 20/02/2009 2:34 pm
Its easy but you need to take your forks to bits. There is a guide on MTBR if you search for totem travel adjust. I used a stack of 2mm nylon washers to achieve the reduction on my Lyrics but you can use almost any tube etc that has a 10mm bore.
Posted : 20/02/2009 2:46 pm
