Anyone managed to make an is mounted caliper fit on a manitou post mount fork without increasng disk size ?
Before i go and do a cynic-al on it i thought id ask ๐
Already at 180mm and the forks are qr manitou nixons so id rather not go to 200mm.
Failing that if you want to swap me a smaller hope mono mini caliper for my 180mm is one ( black and gold version)
Posted : 31/08/2012 9:51 am
http://clee-cycles.co.uk/esite/P1043/product
In theory the 160mm mount will allow you to use a 180mm caliper on a 180mm disc.
However, it doesn't fit all fork/caliper setups. I think clee have no issues with returns in this situation.
Posted : 31/08/2012 10:07 am
Thanks . Im also being a fudd - ive had this issue before and solved it then as well - not so impossible it would seem
Posted : 31/08/2012 10:35 am
